91 octane vs 8.3:1
Old Feb 3, 2004 | 03:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
91 octane vs 8.3:1
here in cali, the best they sell is 91 octance gas. is a CR of 8.3:1 sound good for my new 350 i am building? originally i planned around a 93 octane but i was mistaken and found out it was only 91 octance. whats the highest CR i can run on 91 octane?
Old Feb 3, 2004 | 03:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
8.3 is too low.
Aim for about 9-9¼:1.
I had a 400 for part of the time I lived in Carlsbad, with about 10.4:1. When I had originally built it I was very careful about "squish", deburring sharp edges int eh chambers, etc.; all the things one would do to make an engine tolerant of low-ctane fuel. I could get it to work out there, but I had to back the timing well off of optimum. So that is clearly too high.
Old Feb 3, 2004 | 04:12 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
305s and L98 350s mostly have 9.3:1 compression as IIRC, they run on 87 gas. There isnt any reason you cant bump it up a bit.
91 thats it?? Man I will never move there, Super smog laws + 91 gas = not as much fun/ more $$ to get the same results.
Im living in OH(for now), but back home in MI we can get 94 SUNOCO at the pump! Also, they dont test us for anything smog at all.
Old Feb 3, 2004 | 06:33 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
TraviZ - Still building a stroker?
Old Feb 4, 2004 | 12:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yes..
all im waiting for is my tax return check.. then the fun begins
Old Feb 4, 2004 | 01:36 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
these pistons i had in mind had this ratio
# 64cc Head: 10.4:1
# 76cc Head: 9.1:1
and the heads i chose though have 70cc..
so that should come to 9.6:1 CR.. sound good eh?
Old Feb 4, 2004 | 01:55 PM
Car: '85 IROC
Engine: LB9
Alum or iron heads?
It depends upon the cam too tho, but since yours is a TBI it'll be a small cam.
Zero decked?
KB has a good CR calculator, but they just updated their site so the link i have won't work, but if you type in kieth black pistons, it will get you there.
I'd think that with a TBI cam the CR of 9.5:1 or so is right for alum heads or lower with iron.
Did you get my PM?
Old Feb 5, 2004 | 12:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
http://www.jegs.com/cgi-bin/ncommerc...71&prmenbr=361
im assuming its iron
Old Feb 5, 2004 | 12:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those are aluminum.
9.6:1 should be fine with them.
The numbers I gave were for iron. With aluminum, you can get away with higher static CR; in fact, you need a higher CR.
Old Feb 5, 2004 | 01:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok thanks alot! that just answered my question perfect. but can i ask, where did u read that they are aluminum?? i couldnt find it.
Old Feb 5, 2004 | 01:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I believe all sbc edelbrock heads are aluminum.
Old Feb 5, 2004 | 01:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
yup
Old Feb 5, 2004 | 01:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok then!
1fast91
Sep 8, 2015 01:48 PM
masonta
Sep 1, 2015 06:40 PM
Justin92GTA
Aug 27, 2015 11:16 PM
355tpipickup
Aug 13, 2015 07:35 AM
