engine combo?'s
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
engine combo?'s
ok, after deciding i don't have enough patience to build a turbo motor, or enough money to build a procharged motor, i've decided N/A is for me.. i'm looking for a good strong weekend driver here's wut ive come up with but i have some compatability ?'s
zz4 block bored .030
fast burn heads
speed pro forged pistons
HOT cam kit
stealth ram intake
36psi injectors
gen 7
questions are:
does anyone know FOR SURE weather the stealth ram will work with fast burn heads- gmpp says will take standard or vortec manifolds
can hot cam be used with fast burn heads?
thanks for ur help
fast burn heads
HOT cam kit
stealth ram intake
36psi injectors
gen 7
questions are:
thanks for ur help
IMissMy86TA
Aug 31, 2015 08:40 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
