@ questions-- OIl pan leak??? OIl on plugs??????
Old Jan 29, 2001 | 10:43 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
How hard is it to remove the oil pan? Whats involved? I have a leak at the rear and I hope its the pan gasket. Easy to do?????
Second, I removed my plugs yeterday to check them and noticed that the plugs are fine except for Some of them, on the threads, are covered in oil its only on the threads though. What is this?
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
Old Jan 29, 2001 | 05:01 PM
ede's Avatar
ede
unless i was leaking a lot of oil i'd leave the oil pan alone. i'd say your valve cover is leaking oil on your plugs
ICON Motorsports
1st & 3rd
Old Jan 29, 2001 | 07:25 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm with Ede on leaving the pan alone unless its really bothering you, might even be the rear mian seal.
As far as the oil on the threads of the plugs, this is my thought,
If there is no obvious leaks (valve cover, Etc.) the oil usually is caused by the oil in the cylinder creeping up the threads of the plug. It isn't very much oil and it doesn't burn off because its up the threads where the combustion process can't get at it.
It works just like WD40 penetrating up the threads.
Thats how I think the oil gets there.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited January 29, 2001).]
Old Jan 30, 2001 | 11:10 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
Just started to leak and it isnt that much So I will leave it alone for now. I dont see any oil leaking from the valve covers so I will asume ita what engineboy said. Thanks..
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
gwade12
Aug 8, 2015 08:17 AM
