cam and intake
Old Feb 6, 2004 | 06:49 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
cam and intake
I am thinking of getting Edelbrock Performer cam and intake for my TA85 lg4. Does anybody know if this will work with the computer stuff and what hp gains I can hope for?
Old Feb 6, 2004 | 07:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The intake is OK but isn't alot different from the stock one. Not a good "results per $$$" kind of item. If your existing intake isn't defective (cracked, broken-off thermostat bolts, etc,) I'd leave it alone.
The cam is not a good choice. I would not recommend it for anything.
Look at a Comp Cams XE262. It is a far better piece. Crane and others have similar designs that also work well; people say the Crane Energizer 272H is a good choice, but I've never used one so I don't know from personal experience. Look for a cam with the steepest possible ramps, so that the valves stay closed as long as possible, and then when they start to open, they open as fast as possible and stay at high lift for as much of their open time as possible. The Edelbrock cams are copies of ancient generic designs that work OK, but alot of better designs have come along since those grinds were invented years ago.
On that engine, the intake isn't the limit to its current performance anyway, so you will gain very little by changing it, no matter what you put on it. The biggest improvements you can make are THE EXHAUST first, all the way from the heads to the street; and after that, the cam; and adding the HO air cleaner in the process.
Old Feb 6, 2004 | 09:19 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
camshaft
Thanks for the input. Will the XE262H cam work wiyh the stock torque-converter?
Old Feb 6, 2004 | 09:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It will work; but it will greatly appreciate an improvement in that area. If you don't want to change it, use the XE256 (or equivalent) instead.
beastin91rs
Oct 9, 2015 07:38 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
hayesaw0210
Aug 23, 2015 11:15 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
