not turning over
Old Feb 6, 2004 | 07:13 PM
3504mula's Avatar
Car: 90 Formula
not turning over
I know there have been a bunch of posts like this, but I need some help...
I posted this not long ago, but I got it running and it was ok for about 2 weeks. I have always had problems with my car not starting. I had a new starter installed, but that did not help. So, I ran a starter switch which worked fine for about two years. Now, I am having the same problem. The starter switch is working, since I tried touching the two wires together, but still nothing. I can hear the starter relay click, but not the solenoid. 2 weeks ago, I had this same problem, and out off frustration, just messing around, I just tried to tighten down the bolt that goes through the two brass looking rectangular tabs off of the starter/solenoid, since it was loose and sparking when my gf turned the ignition. As soon as I tightened the bolt it fired right up, and I didn't have any problem until yesterday. I now wonder if that was my problem at all. My car is at work and in a bad place to work on it, but I will have to, so is there any thing else I should check once I get under there?
Thanks for any help.
Old Feb 6, 2004 | 07:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the solenoid, is the wire with the small lug on the "S" post or the "R" post.
I had a similar problem and found that the connection inside the starter solenoid was broken at the post. You might need a new starter solenoid. After re-reading your post, do you still have the VATS in your car or have you disabled it?
The Trickster!!!!!!!!!!
Old Feb 7, 2004 | 09:34 AM
3504mula's Avatar
Car: 90 Formula
unless the guy before me disabled it, it is still there...the security light flashes and then turns off when I crank it up, if that means anything...is there some way to jump the starter just to get the car cranked so I can get it to my house and in my garage?
THanks again
Old Feb 7, 2004 | 01:41 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Use a screwdriver to short between the S post and the 12 volt feed. That should bypass the solinoid and put 12 volts to the bendix and starter motor.
Not easy or fun, but should get you started as long as the starter motor itself is good..
BE CAREFUL! Make sure there are no fuel leaks in the area, as sparks WILL FLY!!!!
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
