Need Engine Project Advice
Old Feb 7, 2004 | 10:51 PM
noc_81's Avatar
I'm planning on starting a project to keep myself from going stir crazy. I figured I'd try to replace any gasket I can reach without needing an engine hoist, and also doing some work on the cylinder heads.
I'm going to be doing most of the work on a budget, so I figured I'd do some minor porting and gasket matching. Could I just do it with a heavy drill along with some sand rolls and a single carbide bit? Also, I figured I should o-ring the cylinder heads. Would I have to use a copper head gasket, or is a normal gasket going to seal? Or, then again, is there a good pre-o-ringed gasket out there? I believe it is a '70 z28 block, and the cylinder heads are 305ci 601's.
Would it be easy, and cost-effective, to pull the cam and replace the seals? And afterwards, would I need to degree the cam (?) or do I just line up the dots on the timing sprockets?
Also, are there any plugs on the engine that I should replace? The idea is to try to restore as much performance as possible without messing with the crank and rods.
Old Feb 8, 2004 | 12:44 AM
Morley's Avatar
Are you running under heavy boost? If not there is no reason to O-ring the heads/block (and this should be done by a machine shop anyway) The only V-8 ( N/A) that needs O-rings on the head gaskets are Fords, they only have 10 bolts per head, the SBC has 17, much more clamping force there.
Old Feb 8, 2004 | 07:33 AM
ede's Avatar
ede
o rings require copper gaskets. if you don't mind using the wrong tool for the job a drill would be great to do the port work with. there's no seals on the cam so pulling the cam to replace them is pointless. there should be 8 plugs you need to replace, 4 in each head at the end of the plug wires. you don't need to degree the cam, i doubt if you could or have the tools to do it with anyway. you have to match timing marks.
Old Feb 8, 2004 | 09:44 AM
Morley's Avatar
By "plugs", I think he may have meant freeze plugs and oil galley plugs.
Old Feb 8, 2004 | 01:10 PM
ede's Avatar
ede
yeah i wondered about that, but freeze plugs and oil plugs aren't usually part of a PM process.
Old Feb 8, 2004 | 04:07 PM
noc_81's Avatar
What head gasket would you guys recommend? I can't go spend a bundle on a SCE, but I should be able to shell up $30. I saw a set of copper head gaskets in the 'new products' section of a recent summit catalog that were like $20. Ever hear of Flatout gaskets?
What seals, bearings, and gaskets can I replace without having to pull the egine, besides the the top-end? I just want to do what I can to restore some performance.
Also, since I only want to get one porting bit, which is the most versatile?
I didn't mean spark plugs. The guy I bought the car off of jury-rigged a lot of stuff, so I don't hold too much faith in his rebuild skills, plus 4 years of 'shop work' before I started doing the work on my own. I guess I'll just check the condition of everything, and replace what is necessary.
Old Feb 8, 2004 | 04:54 PM
ede's Avatar
ede
no bearings you can replace, the gaskets and seals you find as you go. i'd run a regular old coated fel pro head gasket. you don't need copper. as for a carbide bit i'd buy a 1/2 single cut cylinder with radius end.
Old Feb 8, 2004 | 05:49 PM
noc_81's Avatar
Got a simpler description of what it looks like?
Also, when cleaning up the heads, how much should I take off the combustion chamber? I'm not planning on replacing the valves, so should I be carefull not to do much work around the shrouds?
Also, is this tool what I need to get the springs off to remove the valves?
Old Feb 8, 2004 | 05:54 PM
noc_81's Avatar
The 305 heads are making a lot of compression, so should I go with a beefy gasket, or just a stock fel-pro?
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
