are our headlights sealed with gas ?? or....
Old Feb 8, 2004 | 02:26 PM
SeanTimothy's Avatar
im asking because i want to drill them and put strobes in them....now ...are they sealed and wont work if theres a hole in the,.....or will they work if they are drilled?
Old Feb 8, 2004 | 03:06 PM
86TATpi's Avatar
Lights are sealed. Either with a vacuum or a gas. Headlights have a halogen gas in them. The sealed light allows the filiment to burn hotter without blowing out. So drilling into them will release the gas and they will blow out quickly. It will say sealed beam. 3rd gen f-bodies have them.
Old Feb 8, 2004 | 03:09 PM
yea...these say sealed.....Doh....no strobes in the lights i guess.....
Old Feb 8, 2004 | 03:29 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I know one of the lights I bought for my car
kinda the same as yours
had the outer shell with glass and all then inside there was another light bulb
and even put a whole in the glass shell one time by rock but it still worked
kinda just need to check it out but I make no promise
Old Feb 8, 2004 | 03:41 PM
i dunno....my RX7's lights had the same thing happen and they worked.....but yeah....only one way to find out, do it.....i might take a old headlight and break the lense, see if it works after that, before i go through all the work and drill these...
Old Feb 8, 2004 | 06:14 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Somebody had busted my lense and my bulb still worked. So maybe to answer your question. Theres a bulb inside the lense its just a closed lense.
Nate
Old Feb 8, 2004 | 06:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe Hella makes a kit to turn our H6054 setups into those little "replace just the bulb" setups, like on newer cars with fixed plastic lenses. You might want to look into that. Then you could use those highly annoying super-hyper-ultra-blue-white damn bulbs that every moron and their girlfriend is putting into their cars (please don't).
Old Feb 8, 2004 | 07:03 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
well its with our cars sitting so low to the ground I dont think it matters much. Theres always gonna be the ******* driving down the road with his lights in my eyes. (Everyone that passes by) *** I hate other drivers....But ya Im sure you can either fab something up, or rather just get the kit.
Nate
Old Feb 8, 2004 | 09:10 PM
i wouldnt mind that kit, does anyone know a cost, part # and where to get them????
Old Feb 8, 2004 | 09:15 PM
Morley's Avatar
Google maybe?
Old Feb 8, 2004 | 09:41 PM
blah google sucks, i tried it actually lol....
Old Feb 8, 2004 | 09:47 PM
joshwilson3's Avatar
Old Feb 8, 2004 | 10:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
G0D I hate those things. Especially when they put them in the high beams and leave them on at all times so its like they have a high end BMW or something. When someone comes up behind me with them I just slow down to around 35 on the highway, make them pass and get behind slower traffic, and then accelerate back up to 90 or so and loose them. Even get the pleasure of seeing them get all bent out of shape when I go to take an exit.
Old Feb 8, 2004 | 10:47 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
There is a way to make our lights fixed with replaceable bulbs. Buddy did it to his 87 S10 which I believe has the same lights. Im not sure where he got it ill have to ask.
Old Feb 8, 2004 | 11:01 PM
Morley's Avatar
Conversion kits http://www.autobarn.net/ckseries.htm...01&PID=1408109
Result from Google search.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
