Valve Cover Holes
Old Feb 1, 2001 | 11:06 AM
El Guapo's Avatar
Valve Cover Holes
Here is the setup. 87 T/A with a 350 out of an 87 TBI truck. Has Edelbrock Performer 1406 carb and a non computer controlled dist.
The valve covers on it are the stock ones. It has a large hole on the pass side that currently has a PCV valve and a hose going to the open air element. The driver side has a tiny opening that is currently blocked off. ls this ok, or am l messing up somewhere?
Clayton
Old Feb 1, 2001 | 01:35 PM
Guest
Guest
Posts: n/a
The setup should have a PCV (was originally on the driver side) and then its a tossup. I have seen some with a second PCV and then theres others with just a breather tube. That is what I would do, run the other hole into the open element as well.
Old Feb 1, 2001 | 07:40 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
PCV valve should go to a constant vac. source.
The other side can go to the air cleaner or just have a breather.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 2, 2001 | 04:48 AM
SeanSullivan's Avatar
on my 92, the passenger side used to goto the breather, now goes to catch can. the drivers side has the pcv valve, going to carb. yes it's been converted to carb.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
