Gaskets.
Old Feb 10, 2004 | 03:46 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Gaskets.
I'll be doing heads, cam, intake, TBI, etc over spring break, in the 305. What gasket set should I get? The guy at Murrays had only ROL, and I'd rather go with FelPro (for the same price anyway). I know I need head gaskets, valve cover gaskets, timing, possibly oil pan, and vortec intake gaskets. See sig below.
Thanks!
Old Feb 10, 2004 | 04:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can get felpro gaskets at autozone or advanced. Gm gaskets are okay to use as well.
Old Feb 10, 2004 | 06:10 PM
ede's Avatar
ede
fel pro is all i use. got to figure gm gaskets are good too, and i hear sometimes cheaper
Old Feb 10, 2004 | 06:37 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
are standard 305 gaskets the same as vortec gaskets (with exception to the intake gasket, which has the taller intake port) or are the head gaskets different? I planned on saving money if the vortec gaskets were more expensive, by getting a standard gasket kit with additional gaskets for the intake... but if the heads are different then i'll just go with a vortec set.
any part numbers for me?
Old Feb 14, 2004 | 11:36 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
looking for the best but cheapest routine of getting gaskets for my setup. ordering this weekend, starting my build this weekend!
Old Feb 15, 2004 | 08:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Don't get ROL intake manifold gaskets!!
The set I got from them had gasket material covering the coolant hole at the back of the manifold. Over a few miles this gasket material comes apart due to the coolant and contaminates the coolant. Looks like crap.
I myself use Fel-Pro.
Old Feb 16, 2004 | 04:04 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
southern playalistic cadillac funky music
I just ordered $90 in gaskets
FEL-KS2600 Chevrolet: 1957-73 265-350, complete engine gasket kit $39.95
FEL-VS50088R Chevrolet: 1986-present 305/350, center bolt heads, valve cover gasket set $21.69
FPP-1255 Chevrolet: 262-400, with Vortec heads, 1.08 in. x 2.11 in. port size (with tapered wall), intake gasket set $19.88
Old Feb 12, 2005 | 01:29 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
to bring up a dead topic...
will I need to purchase these identical gaskets once more? I'm going to be building a 350 roller block, with vortec heads. Sounds like I need all three of these items again?
Old Feb 12, 2005 | 07:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Generally unless there's a leak you can get away with reusing the neoprene gaskets. i.e. oil pan, valve cover.....
Old Feb 12, 2005 | 12:47 PM
brutalform's Avatar
I believe the quality of certain GM gaskets are better than FEL-PRO. Expecially the center bolt valve cover gasket. Can never keep the FEL-PRO in the rail. GM has the dimples on theirs.
hectre13
Sep 8, 2015 03:38 PM
Chiknhawk
Aug 23, 2015 05:54 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jester
Aug 26, 2005 01:51 PM
88MARO
Mar 11, 2002 06:19 PM
