Lack of power.......
Old Feb 3, 2001 | 01:10 AM
PPonU4Me's Avatar
My car seems to have a real lack of power. By my estimates, I should have around 300hp, but it seems like 150hp. My car bogs when I jump on the pedal, I checked the carb(edel. Perf. 600cfm #1406)and put in a stiffer step-up spring(orange) and the rest should work fine for what I have. What else could it be?
[This message has been edited by PPonU4Me (edited February 03, 2001).]
Old Feb 3, 2001 | 01:17 AM
PPonU4Me's Avatar
The car is an'87 Iroc-Z with a '92 350 4-bolt, bored .040-over with a mild cam. The Manifold is an edelbrock Perf. with an Edelbrock Performer #1406 600cfm carb, GM HEI upgraded with Accel parts. The heads are TBI truck heads and stock exhaust manifolds for clearance reasons.
Old Feb 3, 2001 | 02:13 AM
burnoutrpm's Avatar
ohhhh just wondering?? where did you get thet edlebrock??? go back to the stock step up-sring, read the article edlebrock problem??????? yes, it mine!!!! i had the same damn problem! mine was that i kept getting bad carbs.( brand new!) right fromt the box! did you get yours at autozone by chance??? if so its a good possiblity that you have a bad carb all-round! in the instruction manual you got with the 600 read and follw the instructions to a science and re-adjust your "idle mixture screws"! trust me thats all mine was! are you still using the 700 from your conversion?( yes, im psychic!, no i just did the same conversion!) is the t.v. adjusted right with the correct throttle bracket?(the stock one wont work at all!) that also makes a big difference! the intake sounds great! its dual-plane! good + on the ignition upgrade! thats a great start im getting the proform kit for 77$ through jegs! its got everything from the cap to the springs and 50,000 volt coil. the power loss is from the idle mixtrue screws not being set correct, or.. the floats are out of wack does it seem to surge or idle funny at all?.. honestly??! if it does then its the floats out of wack. thats a big power robber! the idle mixtrue screws are a big power robber! and finally change the step ups back to stock! they dont need to be changed!( your engine is about the same as mine!, literally!) and also get the 700 adjusted to a good carb bracket! dont follow the instructionsin tech articles listed on this site just start out and push it all the way in(fluch with the plastic piece) then pull it out 3 or 4 clicks and take it for a run and note the shift pattern and adjust it acordingly!( how you get the most power out of it!) but what ever you do DONT GET IT PUSHED IN TOO TIGHT! the t.v. is a great hp robber if not set perfect!(trust me!) if ive left something un-clear(no question is dumb) better safe than sorry later.! just email me . oh yeah is everything ok with the conversion? did you use a block pump? also did you keep and use the return line?(very nesseary)!
burnoutrpm@hotmail.com
ask away about any thing!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke 3 of them!.
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
[This message has been edited by burnoutrpm (edited February 03, 2001).]
Old Feb 3, 2001 | 03:49 AM
The ODB's Avatar
Man I would really need to look that carb over to be sure what the problems are. If the carb worked good (no bog) before and is more than a year or so old then it is possible you may need to replace your acellerator pump plunger (a plastic & rubber piece). When they wear & no longer seal they sometimes cause a bog. Other common things with an aging Edlebrock is the very small passages like the air-bleed tubes and the acellerator pump nozzles. The small tubes can get clogged with dirt and moisture, and also alcohol (ethanol or methanol) mixed with your gasoline can cause corrosion that blocks those tubes up.
Other times a weak or faulty ignition system can cause the symptoms you describe. Luckily it is easy to swap carbs with a buddy who has one running good just to test if it's the carb.
good luck
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, single 3" Borla exhaust, Linginfelter-TPI camshaft pulls 17" vacuum solid. N/A runs 10.9 @124, Crack-runs 10.3 @135... haven't run at track since Oct-99
Old Feb 3, 2001 | 06:29 PM
vortech305's Avatar
Its your camshaft
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Dwayne614
Sep 29, 2015 11:05 PM
mdtoren
Aug 23, 2015 12:52 PM
