heads for a 350???
Old Feb 12, 2004 | 07:45 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
heads for a 350???
what heads are a good choice for a carbed 350??? i am getting a cam with a 480 lift, intake and exhaust, and i have a holley street dominator intake, and holley carb, and exhaust stuff.....i am lookin for reliability over anything since its my daily, but want more power than stock....should i get vortecs??? i want to be in the 330 hp range thanks
Old Feb 12, 2004 | 09:21 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
vortecs would be a good choice in my opinion. im thinking though that the cam you want may be too much for the stock springs on the vortecs. gmpp sells a set that are machined for a bigger cam. i think stock vortecs are like 450.00 and the machined ones are like 650.00. i have the world products sportsman II's. they are excellent. larger valves and cc's than the vortecs, but also larger price. like 800 - 850.00
Old Feb 12, 2004 | 10:35 PM
Engine: 350 carb
well in summit theres vortec gmpp heads that say it comes with springs that accomodate up to a 480....but would a little smaller cam benefit me better on the street??? like maybe a 472 or something???
Old Feb 12, 2004 | 10:36 PM
Engine: 350 carb
and will a holley street dominator intake work on vortecs, cuz i know only some intakes do.
Old Feb 13, 2004 | 06:08 AM
Engine: 355
when i built my engine, i had an idea of what cam i wanted to run. to double check myself, i called the cam dealer (Lunati in my case) and asked them their opinion. they helped me out tremendously. they asked me everything about my car and my engine, and what i planned to do with the car. cam selection is one of the most important decisions. i used a smaller lift cam so that i would still have plenty of vacuum for my brakes. i run a .455 lift. as far as the intake, i dont think the dominator will work on the vortecs because of the different bolt pattern.
Old Feb 13, 2004 | 06:32 AM
ede's Avatar
ede
vortecs would be a good and cheap choice
Old Feb 13, 2004 | 09:09 AM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
Your cam should be ok
My friend has a 488 lift in his 305, and he drives it ok everyday
Vortecs are awesome heads for the money!
Old Feb 13, 2004 | 03:28 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I wouldnt risk anything bigger than .470 on vortecs. They are great heads for the money. If you go with a little bit smaller like in the .450 range. Also I dont think holley makes an intake that fits vortec heads. The performer RPM intake will work better with them anyway. Good Luck.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
