Will This Work?
Old Feb 4, 2001 | 02:19 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Will This Work?
I am putting in a GM Goodwrench 350 and I was going to use my stock intake and carb from my 305, but my brother said he wasn't sure if my old carb will be able to give the 350 enuff fuel and not starve it. Has anyone had this experience or know if I need to buy a new carb.
Old Feb 4, 2001 | 02:29 PM
ede's Avatar
ede
unless you want to deal with a lot of ecm related problems you'll have to keep the same carb and intake as far as i know. it should supply the bigger engine just fine unless you run it at higher rpm for extended periods of time.
ICON Motorsports
1st & 3rd
Old Feb 4, 2001 | 03:02 PM
Guest
Guest
Posts: n/a
If its computer controlled, thats not as a big of a deal as it might seem. You can change the rods without it knowing any better, and richen it up. Ask on the carb board, Im sure someone can point you in the right direction. GM also has the ZZ4 conversion, which uses a couple different parts for the carb to make it work with the ZZ4.
Old Feb 4, 2001 | 03:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
GM sells the "HO 350" conversion kit, and they were generouse enough to give a breakdown of the parts.
Under the catagory of "calibration" they list:
ECM: 1228079
PROM: (depends on year)
Knock sensor: 10456288
ESC Module: 16128261
Secondary Metering rods: 7033812
Cooling fan switch (95*C): 3053190
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 4, 2001 | 03:39 PM
Car: 99 Formula
Axle/Gears: 342
well i bought a new accel hei dist. and it doesn't have the hook up for the computer, so that shouldn't have any effect right, which means the comp. is totally disconnected right.
Old Feb 4, 2001 | 03:44 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If it has a vacuum advance, then don't worry about the computer stuff, but do pick up the secondary rods. I would take a look at the "carb" board, they may have a better suggestion than the "AH" rods that I gave the P/N for.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
