I know I know...another break in questionarre
Old Feb 15, 2004 | 05:01 AM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
Hey all
I have searched and read all of the break in procedure posts on here. Why oh why are there so many different ways?
A local mechanic I know who races says this is the start up break in procedure for my type of setup (flat tappet hydraulic camshaft)
1. 30wt oil, start up get it to above 1500 RPM as fast as possible, and rev it between 1500-2400 RPM slowly for about a 20 mins to a half hour.
2. Take it out with the same oil in it for about a half hour. ( I think thats what he said )
3. Change oil and filter, take out again and run it, do some mild accelerations to about 5000 RPM a few times.
4. Same, but do it with a bit faster acceleration a few times.
5. go drive for an hour or so.
6. cme back and change it again.
7. take it out, and take care of it, but do a few more mild and harder accelerations.
Then there are others who say baby it?
I just want this engine to last me a VERY long time. It's so pretty and will sound good and I don't want anything on it to break, so I am trying to figure out the absolute best way to do things here.
thanks so much eeveryone, I know your all tired of hearing these break in thingies
cheers ya'll!
Old Feb 15, 2004 | 06:52 AM
ede's Avatar
ede
never seen anyone say to baby a new engine.
Old Feb 15, 2004 | 08:40 AM
Morley's Avatar
Fill with 30 wt mineral base (regular dead dino oil) oil. Start the engine, keep RPM's between 1500 & 2000 for 20-30 minutes. Change oil and filter. Drive the car for 500 miles at varying RPM's but keep them below 5000. Change oil and filter again and you're set.
Old Feb 15, 2004 | 10:33 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
SSC does But what do I know, my race engines last more then one season.
Old Feb 15, 2004 | 03:48 PM
x_wolf's Avatar
Car: 91 Camaro RS
what about those that say run it a bit hard so the rings seat correctly?
I just want the best possible break in!
cheers
Old Feb 15, 2004 | 04:08 PM
ede's Avatar
ede
ok i've saw one person say to baby a engine. what exactily is it you do or don't do? my guess is liek a lot of other things related to cars 2 or more differant approaches will work and give the same end results. not sure if lasting more than one season is good or bad. i've had race engines last one nite week after week but it was expected and they did give good service and make good power, for one nite. rebuild and race again next week end.
Old Feb 15, 2004 | 04:43 PM
Morley's Avatar
What I wrote was from the break-in proceedures that came with my new GM engine. Also, when the car was new they said the same thing about the 500 miles below 5k RPM.
Old Feb 15, 2004 | 04:59 PM
x_wolf's Avatar
Car: 91 Camaro RS
heres what the engine manufacturer says.
So many different ways.....which is best?
cheers
edit: adjust tappets? Why and what would that matter?
Attached Thumbnails I know I know...another break in questionarre-breakin.jpg
Old Feb 15, 2004 | 05:26 PM
Morley's Avatar
Solid lifters.
Old Feb 15, 2004 | 05:27 PM
x_wolf's Avatar
Car: 91 Camaro RS
I have hydraulic lifters. This must be just an in general break in guide then. Does it still apply?
Old Feb 15, 2004 | 05:34 PM
Morley's Avatar
With hydraulic lifters you shouldn't have to readjust after break in, unless you adjusted them wrong the first time around.
Old Feb 15, 2004 | 05:35 PM
x_wolf's Avatar
Car: 91 Camaro RS
They came set from the guys that built it. I just put the block in and put a carb on it and hooked stuff up.
ok thanks. So does that guide sound like its pretty good? I'm so confused on the right thing to do.....
cheers and thanks
Old Feb 15, 2004 | 05:51 PM
Morley's Avatar
Follow the mfg reccomendations.
Old Feb 15, 2004 | 06:48 PM
x_wolf's Avatar
Car: 91 Camaro RS
hmm ok even though they say give it some hard acceleraton....will do.
thanks again
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
