How do you check the ign module
Old Feb 6, 2001 | 03:36 PM
R.O.B.'s Avatar
I was just reading another post, and they mentioned the module could be preventing his car from reving high. I didn't know the module could work, just not well. I was under the impression the module either worked or was dead. Well, how do you tell if it is ok, although it works?
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 6, 2001 | 03:48 PM
HIX5000's Avatar
Most parts stores can run a test on the ignition module. However the test is not a 100% accurate. I had a module tested on two seperate days and it tested good both times. So I replaced the module anyway and the car was fine after that.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
middian
Sep 5, 2015 01:42 AM
