Help me determine the right axle
I want to find a 90up, posi, disk, 3.42 gear'd rear end. When I go to the junkyard, how will I know I've found what I want? Is there a code somewhere stamped on it? I really dont want to pull the cover off a bunch of diff's and count gears, is there a better way?
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
You will still have to pull the cover but.......Pull it off and spin the gear around until you see numbers stamped on it. Bring a calculator with you. There will be a ratio in the format XX.XX such as 62:17. This is a ratio off of a locomotive but you get the point. Do the division in the calc and you got it.
bsa
[This message has been edited by irocbsa (edited February 07, 2001).]
bsa
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Those rears only came on 305 5-speed cars with dual-cats. So look for those. You can also spin the wheels and count the number of times the driveshaft spins. It'll be 3.42 times or so (round it to 3.5)
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
rudolphschenker
Sep 4, 2015 02:41 AM
