fuel pump not pumping
Old Feb 20, 2004 | 10:31 PM
willis2z's Avatar
Car: 1989 IROC Camaro 1LE
Engine: 383
Axle/Gears: Dana 3.55
I got an 89 Camaro, went home one day woke up the next morning went to start the car would not start, notice the fuel pump was not priming, assumed fuel pump was out, changed fuel pump, fuel pump relay, still nothing Applied power to the "G" terminal, pump works. What the hell do I check next Thanks in advanced Willis
Old Feb 20, 2004 | 10:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you check the 20 AMP fuse up by the battery. On my 89 Iroc it is by the radiator behind the right headlight.
Old Feb 20, 2004 | 11:02 PM
willis2z's Avatar
Engine: 383
Dude, I just replaced that $160 fuse But that was the problem. Thanks for the reply
Old Feb 20, 2004 | 11:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
For it to only cost $160.00, you must have changed the pump and relay yourself. But just think of all the experience and wonderful vocabulary you have gained because of that insignificant little 25 cent item. Sorry you didn't post here sooner!!!!!!!!!!!!
Old Feb 21, 2004 | 12:57 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
It seems to me that a whole lot of people here post when they have a problem AFTER they have tried to replace several parts... when they could have avoided all that...LOL...that sux. mine went out the other day and first thing I checked was the fuse. Cost me 2.79 for box of 20amp fuses. Problem fixed. (not to rub it in at all) Hope things work out better next time. Utilize this board as much and as often as you can.
Old Feb 21, 2004 | 10:16 AM
willis2z's Avatar
Engine: 383
Both of you are right.should have done my homework first.i didn't know there was a fuse there.mine was hidden behind the burnoff relay.at least i have the piece of mind knowing i have a new fuel pump.by the way anyone need a slightly used one
Old Feb 21, 2004 | 10:31 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello willis2z,
If you found it in the general area of the battery, those are fan relays. The burn-off relay is located on the firewall on the drivers side. The relays are the same for the burn-off and fans though.
Old Feb 21, 2004 | 01:36 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Probably didn't waste anything... wonder what blew the fuse?
Fuel pump maybe?
(Trying to make you feel better!)
Old Feb 21, 2004 | 01:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Probably some bare wires at the fuel pump relay. They are notorious for the insulation getting oil soaked and peeling away from the wires at the connectors. If the power wire touches another wire it will short and blow the fuse.
Old Feb 21, 2004 | 02:37 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You still could have had a bad fuel pump. Often times, the pump will short internally, causing a high amperage draw that blows the PCM B+ fuse. Put 12V across the old pump and see if it spins.
P.S. You should ALWAYS check for power at the fuel pump before replacing it. I use a taillight bulb across the gray and black wire at the fuel pump.
Old Feb 21, 2004 | 03:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Applying 12VDC across Pin "A" & "G" works just as well and faster. I took a hint from another board member and used a 14.4 volt battery from a cordless drill and a homemade connector to test mine. Pump runs good with this set-up.
Old Feb 22, 2004 | 10:43 PM
willis2z's Avatar
Engine: 383
The fuel pump was stuck.After i took it out i applied 12 volts to it and it didn't pump.Then i did it a couple more times it spun.no bare wires and no grease in this engine bay.by the way the pump was orig. with a little over 23000 mile on it.The car sits up alot.I guess age got it.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
92camaroJoe
Aug 13, 2015 06:07 AM
