A few bugs to work out.. help
Old Feb 22, 2004 | 11:47 PM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
OK.. i have a couple things here to figure out any help pleas!!!
1....Rpm's seem to be running about 1500 to 2000 high
2....Speedo works only occasionaly and when it does it only goes to like 30 mph and back and forth... then SES light comes on
3....Oil pressure is pegged over 60 psi and stays there
4....Temp gauge peggs when key is turned then goes back to 100 and stays there and does not heat up even after 2 hrs of driveing
everything i am having probs with is in the cluster.. anything that could cause it all or is it just alot of things adding up??
this is a 91 Z-28 305 TPI with auto tranny..... please help me thanks in advance...
Old Feb 23, 2004 | 10:50 PM
3rdGenSS's Avatar
ttt
no one has any clues to any of this weird stuff?
Old Feb 23, 2004 | 11:26 PM
CaysE's Avatar
My initial thought is the ground between the engine and firewall or between the battery and the frame. Have you checked any voltages?
Old Feb 24, 2004 | 12:50 AM
3rdGenSS's Avatar
no i havnt checked any voltages yet.. i just got the car and was fixing a few other things...though i did get the codes that brought the SES light on.. they are 24 and 34.. not sure if that has any effect on the cluster readings or not.. ill try to get the voltages tomorrow... if the snow doesnt keep me busy with other things. lol...i just want to get this all worked out before i start putting in the 4th gen interior and all..
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
