ATTN: Anyone considering Accel Header spark plugs
Ok, I blew 30 bucks on these POS plugs about 2 months ago. Only reason I bought them is because they were shorter than AC Delco's and I needed the room. Well, after doing some research, I decided to give the NGK's a try.
When I got my headers installed yesterday, I pulled my Accel plugs and put them side by side with my NGK's.... thier the same size!
Plus, on 5 of the 8 plugs, the screw on tips were loose and about to fall off. Never again will I waste my money on those.
The NGK's I have are the UK5 V-power series and I paid $13 for the set.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Bosche plugs are also the same length as the Accell's. I too have heard about the Accell's coming loose and falling apart. You could always use a standard length plug and just use a modified spark plug socket that will allow you to have access to the plugs around your headers.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive used accels for about 3 years in various cars with headers without problems.
you should tighten the spark plug tip on EVERY spark plug regardless of who makes it. if thats your only complaint, then its your own fault...
btw, SOME ac delcos are also shorter...
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I too am using the Accel plugs, no problems. I agree with Mrdude you have to snug up the tips with a pair or pliers before installation.
I did.... and did it again after a month when I pulled them to check how they were burning.
The problem wasn't in getting a socket on them with the headers installed but with my old flowtechs, the number 8 plug wire boot was so close to the header that you could barely slip a piece of paper between them. Now with my Hooker 2460's, I got plenty of room; even if I were to switch back to an AC Delco plug.
I know some AC's are shorter but i was using the R43TS's. Not sure about the others.
Car: 91 Camaro Vert
Car: 2002 Formula Firebird
Transmission: 4l60e
I used to use those plugs...I got them from a local speed shop for 15$ a set thought. With my hedman LT's normal plugs didn't want to fit. But with my old hooker and the edelbrock's I have now R45TS ac delco's fit fine.
If the accell plugs didnt come loose as easily as they do they would be great.
With my Hookers, a regular AC plug would probably fit just fine but the NGK's give that extra room and plus I haven't used NGK's before. I hope they work out; they were recommended by several people.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I've run Accel shorty plugs and also think they're stupid ...They're barely shorter than a standard plug and definately didnt help with my #7 plug-to-header interference ...even with a HUGE dent in the header tube.
I did not have any problems with the plugs just had to tighten the tips. As a matter of fact the did come in handy as they offered more clearance than my AC 45's. This is just my experience.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
