Everyone with an aftermarket cam, a few tech questions...
Old Feb 8, 2001 | 04:39 PM
Dan87IROC-Z's Avatar
I was just wondering what cams in what engines and with what mods everyone is running? And also how did the cam perform in your car when you first put it in? Thanks.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 8, 2001 | 06:30 PM
ede's Avatar
ede
custom ground lunati roller, i left the brake and gas pedals in the stock location, changed everything else
ICON Motorsports
1st & 3rd
Old Feb 8, 2001 | 08:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My 383 had a Crane CC-290A and was driven on the street when I bought it. Too bad the previous owner didn't have higher compression and a higher stall converter. When I bumped them both up I picked up 2 full seconds. Went from 14.0 to 12.0
The big block has the biggest Xtream Energy cam available, XE294H and it might not be enough.
My brake and gas pedels are also still in the stock location but I may be moving them back so I can move the seat back to transfer a little wieght to the rear.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 9, 2001 | 02:40 AM
DAMN!!!! 2 seconds, my gosh...
Old Feb 9, 2001 | 03:31 AM
Ski89Z28's Avatar
I screwed up alot but I'm learning!
I had a head gasket blow so I decided to get new heads AL and a new cam. So I bought the Edelbrock 6085 heads and TPIS ZZ9 cam. I didn't know about this web site then so I got these cause I had catalogs from them. I didn't know about AFR heads till months later and not to mention the other cams that are cheaper and just as good as the ZZ9 and an aftermarket intake would REALLY help.
Well I had problems after it was installed ... basically idle was real choppy. I reset the timing, TPS voltage and IAC, new plugs and wires and still real choppy.
I took it to the track this way and ran a 14.01 @ 97.? .
I found out in late Fall my ignition control module was bad and causing the rough idle. But it was too late to go to the track again so I'll wait till spring.
I have stock suspension still and a 2000 stall convertor with a rebuilt tranny and transgo shift kit installed. Headers, Edelbrock ... should have gotten SLP, and a custom dual exhaust but 2 1/4" pipes.
I wasted alot of money so read and learn by others mistakes or by their gains.
Good Luck!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Old Feb 9, 2001 | 06:38 AM
Nitro Don's Avatar
I stuffed a Comp Cam 210/220 .533/.544
Things really woke up last week when I got the trans back with a 9.5" 2800 stall converter.
When I get these larger springs in,I might
just have an 11 second 305
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
TCI shift kit
Vette servo
B&M 3-4 upshift kit
TCI Trans Rebuild
2800 stall 9.5" TC
Nitto Drag radials
FUTURE MODS:
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Old Feb 9, 2001 | 01:55 PM
Box of Rocks's Avatar
Ede,
I'm like you - I left the pedals alone (well, new bushings for the levers) and rebuilt everything else. My brother is rebuilding the Muncie 21 for me this winter in exchange for me doing the bodywork on his daughters' car. So, other than lifting the body off the frame, EVERY system in the car is new except for the rear-end. That's what I'll break this year.
Ford toploader tranny = easy rebuild.
Muncie = not so easy, and special tool required too.
Ede, I love that line......"left the pedals alone....fixed everything else...."
It's going in my archives of hotrod truisms. Just think if cars came perfect except for the pedals.....then we could leave everything alone, and concentrate on just the footwell.
BOR
Old Feb 9, 2001 | 02:08 PM
The ODB's Avatar
*cam in sig
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
gixxer92
Sep 1, 2015 04:32 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
