Valve spring installed height
Old Feb 10, 2001 | 04:52 PM
ede's Avatar
ede
how close to hitting the installed height is good enough? i'm going to buy a couple of boxs of shims to keep on hand and the fewer differant sizes i buy the cheaper it is on me. i can always stack shims to get the thickness i want. i was thinking .010 and .020 would get me with in .010 or .005 and .010 would get me with in .005. so how close is close enough? i'm tired of trying to build heads and not having shims.
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited February 10, 2001).]
Old Feb 10, 2001 | 05:14 PM
Guest
Guest
Posts: n/a
Missing a decimal place or am I reading it wrong?
Anyway, since you have to keep coil bind away by about .060, you should match the installed height to about .010-.015 and you should be fine.
Old Feb 10, 2001 | 05:40 PM
ede's Avatar
ede
max i was thinking if i was within .005 or .010 i'd be ok, but i could never find anything in my manuals that said for sure. sorry max i did get ahead of my self a little in the places and zeros ,i'll edit and fix it
ICON Motorsports
1st & 3rd
Old Feb 10, 2001 | 06:18 PM
Guest
Guest
Posts: n/a
Yea, I dont think thats something you would find in a manual. Thats where we tried to set stuff up at in the shop. Spring rates arent that accurate anyway, trust me.
Old Feb 10, 2001 | 09:10 PM
Vader's Avatar
Ede,
If you're concerned about the spring providing seat pressure, 80 pounds is generally enough on most intake valves under 2¼" diameter. Most aftermarket and performance springs start at over 100 pounds pressure at installed height.
If you have to settle for an installed height that is not exactly the OEM or design spec, install them a little taller than the specification if you can tolerate the extra rocker height. The extra lift before binding is preferable to the few extra pounds of seat pressure you might get at design height. If you've aleady machined the pockets to a given depth, try to get close to maintain valve train geometry, but don't worry about 5 thousandths - as Max says, the springs you're getting out of the box aren't 100% inspected and not that tight on tolerance.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
