Am I using the right distributor gear?
Old Feb 26, 2004 | 08:42 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I'm running an LT4 hot cam and a vacuum advance HEI distributor with an in-cap coil. Last time I had the distributor out I saw some wear in the teeth. It didn't appear excessive but I'm just concerned that maybe the OE gear isn't the right one for this cam.
Old Feb 26, 2004 | 09:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The OE gear is the right one, since it's an OE cam.
But if your gear has wear, it certainly wouldn't hurt to replace it. You don't need a bronze one. Just make sure the one you get is the austempered type, that the factory calls "melonized" (whatever that's supposed to mean....); and that it's the right inner diameter for your particular dist shaft, which will be either .491" or .500".
Old Feb 26, 2004 | 10:22 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Get the GM one for roller cams.
I had the same problem and it will just get worse. It doesn't matter if they are both OE cause GM never put OE mechanical distributors on roller cammed engines. You need the GM one that is "melonized iron"(hardened the same way the cam's dist gear is)like RB said. It is a bit pricey, but it works great and you will have no more wear at all. I have first hand experience with this matter and the last thing you want to happen is for your distributor gear to fail while you are driving. I wish I could show you a pic of what your gear WILL eventually look like let me just say it's not good. I knew to replace it on my HOT cam but I ran an old style distributor on my L98 and chew city. Just go to www.gmpartsdirect.com and look up the distributor gear use with roller cams.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
beastin91rs
Oct 9, 2015 07:38 AM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 17, 2015 07:57 PM
