Ok my car is freakin me out
Old Feb 25, 2004 | 02:18 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
ok so when i start my car my temp read out goes straight to 260 or whatever and stays up there the whole time i drive... and sometimes drops like 10-20 degreees when i shift and then will climbs back up, now i know the engine is not that hot also my gas milage sucks monkey *****...seriously...could the air filter affect the milage??? so if someone could tell me whats up with my car that would be apprechiated :hail: .
Old Feb 25, 2004 | 05:27 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
An air filter can affect your gas milage, but I wouldn't think it would be very significant unless it gets really bad. If its dirty though, get a new one, if you want your car to last and work well you need to take care of it you know
As far as the temperature i'm not really sure about that one, the sensor for the temperature could be shot, but i'm sure there are other possibilities.
Old Feb 25, 2004 | 05:41 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
yea, i'm wondering if the temp sensor being shot would tell the computer to make adjustments or whatever regarding the crappy mileage. i think they're pretty cheap to replace, so even if it's not the problem then you didn't lose any money. maybe the thermostat isn't opening all the way maybe your air dam is broken, or gone. maybe too high a mix of antifreeze with water? just a couple ideas
Old Feb 25, 2004 | 05:46 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Well, he says as soon as he starts his car its going up that high, which means he isn't actually overheating, his guage is just screwed up, or maybe both.
Old Feb 25, 2004 | 07:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Is the temp sensor by the # 1 spark plug connected? My wire fell off once and created a similar problem.
Old Feb 25, 2004 | 11:41 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
If the computer is smart, then I imagine it would. Hot engine temp....the computer might richen the fuel mixture in an attempt to cool the cylinders. Cause we all know lean is hot and rich is cool.
Although the computer uses a different sensor than the gauge operates on...so most likely there isnt a connection
Old Feb 26, 2004 | 09:19 AM
Car: 1984 Z-28
Engine: L69
yea, being rich is cool , but i wouldn't know
Old Feb 26, 2004 | 09:32 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
sounds like temp sensor to me. Not sure where yours is located for a V-6. Mines on the intake torwards front of motor on TBI. The one on the side of the block that someone else mentioned is for your fans and is not effected by the temp sensor. However the computer does make fuel/air adjustments based on readings from the coolant temp sensor.
Old Feb 26, 2004 | 10:36 AM
Car: 1984 Z-28
Engine: L69
not too sure, but i think mine is plugged into the intake manifold near/around the thermostat. a haynes manual would probably tell you where it is.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
