What mini starter?
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What mini starter?
I'm thinking of getting a mini starter as the stock unit only seems to last 2 years before it experiences heat soak troubles. What is everyones reccomendations on which one to go for?
I'm currently thinking:
summit mini starter p# SUM-G1660 $157.95
Powermaster p# PWM-9500 $199.98
I'm wanting to clear the hot start problem once and for all. Also, is the 305 153 or 168 teeth for the flywheel? Saves me counting.
Robert
Robert
I am using the one from Summit that you listed with no problems. It cured the heat soak problem with my SLP 1 3/4
Headers and been starting great for over two years now.
Car: 4
Engine: 6
Transmission: 5
I have a CVR one, #5323 I think, it was in the same price range (about $150-160 IIRC). I've had it for about 5 or 6 years now. Works great. I had it on a 10.4:1 400 for its first couple of years, then I've had it on this 305 I have in the car now for the last couple.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
95 Z28 starter. $122.00
Originally posted by RMK
Thanks for the replies.
DJP87Z28,
How much space is there between the starter and the exhaust?
Thanks again
Robert
DJP87Z28,
Thanks again
Robert
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Same here, I have hooker LT's on my 406 and I have plent of room, you just have to use shorter bolts, or do what I did, use the factory exhaust bolt spacers left over from the 95 Z header swap on the starter bolts.
edit: oops i'm an idiot, i didn't push the qupte button, I'm using a starter from a LT1 also.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have a Tilton one with the following specs:
1.9hp Hitachi motor
3.75:1 ratio
10.5lbs
250amp current draw
Jeg's # 454-54-10001 $275.99
I couldn't be happier! Starts fast and no problems so far!
1.9hp Hitachi motor
3.75:1 ratio
10.5lbs
250amp current draw
Car: 1989 C4
Axle/Gears: 307
Ive got one of those on my truck and a CSI one on my bird. I paid a bit over $200 a pop but they work real well especially on hot starts.
Jegs sell's one under thier label for around $150 I'm fairly sure its a CRV (toyota) crossbread starter.
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
That's a little more than I was wanting to spend. It's between the Summit and the Powermaster at the moment. Decisions, decisions
I got the Summit brand ministarter, it says Pro-Torque on the mounting block. I am pretty sure Jegs sells the same product under the Jegs brand product.
My buddy also has a Summit brand mini. We both live in Phoenix with 10.5:1 383 motors. We both have ceramic coated Hooker LTs and they always kick right over, even heat soaked in 100*+ temps.
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I'm also using the 4th gen starter. It's about half the size and weight of the ancient 10MT starter originally used on my '89. Tons of room in there now for any kind of header. Lifetime warranty, too.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Is the 4th Gen starter you're referring to work with a 168 tooth Flywheel (a 10.5 compression 383 with manual transmission)? Will it handle this compression? Is that what the 95 Z28 post was trying to say?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Im using a rebuilt ministarter I bought from a local speed shop, 60 bucks.. no idea who makes it but its worked great for the last 2 and a half years.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
There's a guy here in town who sells nothing but 3rd gen parts (he buys them and parts them out), and he just got a car with a mini-starter... if you want I can see what he wants for it. He's also my uncle in law, so that helps a little!
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
http://www.tommyjohnsonjr.com/bs/index.htm
$119.00
brand new
ball bearings
Pro-Torque
I've gotten two from there so far. One on each bird. No problems whatsoever with them. Only 10 pounds too.
$119.00
brand new
ball bearings
Pro-Torque
Gunner242
Dec 25, 2015 04:49 PM
