tach problems
Old Feb 26, 2004 | 09:46 PM
1987ws6tpi's Avatar
tach problems
i now have a 1990 camaro rs 3.1 when the car is ideling at like 1,000 the tach raeds 4,000 and when i give it some gas it goes past 6,000 the car runs fine but the tach thing is just a little problem i would like to fix . it you guys can help i would be greatfull thanks
Old Feb 26, 2004 | 11:58 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
just take off the dash, CAREFULLY pull out the needle for the tach. turn the ignition to the ACC position and position teh needle so that the current reading is 0. Fire up the car and see if that works. What i'm trying to say is that when you turn the ignition on but don't start the engine the tach should read 0, if not all you have to do is pull the needle out and put it in its proper place.
Old Feb 27, 2004 | 06:20 AM
1987ws6tpi's Avatar
thanks alot man i will try that today after work. thanks again
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
