11 second 82-92 camaro
Old Feb 27, 2004 | 08:08 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
Ive noticed a "book"(at 27 pages I use that term loosely)advertised in Summit call 11 SECOND 82-92 CAMARO.Im curious but dont want to spend $20 on a 27 page piece of toilet paper.Anyone know whats in it?I figured most of the info's here somewhere!
Old Feb 27, 2004 | 08:14 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
i'm thinking it's gotta be boosted man. unless they're referring to an 11sec 1/8mile but na, man. i haven't seen/read it. but, in any case, i bet a STRONG bottom end and a LOT of boost could get you there. who knows--maybe someone on the forums is buying/gonna buy it. but $20 for information is nice. i've already got a few books, so I doubt there will be any new material.
Old Feb 28, 2004 | 07:58 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Im guessing most of whats in that book can be readily be found somewhere on this site, and if you have specific concerns, the book may not address them anyway. Also, it doesnt take a bunch of boost to get a thirdgen in the 11s, there are plenty of members on here who have done it N/A.
Old Feb 28, 2004 | 11:05 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Yeah, you can get into the 11's naturally aspirated w/ the right heads/cam/intake combo, no power adders needed.
Old Feb 28, 2004 | 04:03 PM
Car: 1984 Z-28
Engine: L69
yea, you guys are right. i was thinking 11sec daily driver. speakin' of, is Willie in the 11s yet?
Old Feb 28, 2004 | 04:59 PM
BuckeyeROC's Avatar
Haven't seen Willie's in a LONG time. Mine might run 11's here N/A in street trim after I get it tuned on March 27th. If it doesn't, it'll be VERY close. It's an EASY daily driver. I just drove around today for 2 hrs w/ a friend and we were racing each other and cruising... not a problem at all, idle is tame at 800 or so rpm, stays around 160*, etc. There are many HSR and LT1 combos that runs 11's in daily driver's too. And bolt-on only LS1's can run 11's.
Old Feb 28, 2004 | 05:07 PM
Car: 1984 Z-28
Engine: L69
Are you referring to your 355 in your sig? You should run a torque converter lockup switch if you're not already. That'll shave off a little bit of time. I wonder how a cc qjet combo might work. Man, I wish I had money so I can get all this stuff I want
Old Feb 28, 2004 | 05:14 PM
BuckeyeROC's Avatar
Yes sir, the 355 in my sig. Mild cam, mild stall, mild gears, daily drivable, and I hope to run high 11's after the dyno tune. It's full weight, 280 lbs driver, and runs at the track just as it does on the street. Haven't tried the tc lockup switch yet, might be worth a try.
Old Feb 28, 2004 | 06:20 PM
zerotosixtyV8's Avatar
Car: Camaro
11s isn't that hard to do. if you are making 450-500 HP in a car that weighs 3300 lbs or so you should be running 11s. 450-500 HP isn't hard to attain at all with a 350 and is very streetable.
Old Feb 28, 2004 | 07:51 PM
Car: 1984 Z-28
Engine: L69
I think it's time for me to bite the bullet and get a 350. You know, with your set up and my altitude of 519 feet, you might get deep into the 11s.
Old Feb 28, 2004 | 11:56 PM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
11's ARE possible N/A!!
Old Feb 29, 2004 | 07:47 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Re: 11 second 82-92 camaro
I borrowed the book from a friend of mine who bought it a few years ago. Basically it tells you to get a 400 small block, build it with a certain cam & heads (can't remember the exact details anymore) long tube headers with cutouts at the collector, slicks, high stall converter, etc. Stuff most of us already know. BTW, no spray or forced induction is used.
Old Feb 29, 2004 | 08:58 AM
ponykiller's Avatar
Engine: lo3
Thanks Ricktpi,thats the kind of answer I was looking for.
Old Feb 29, 2004 | 11:01 AM
GSXRCRAAZY's Avatar
Car: 89 RS
Engine: 406
I borrowed the book from a friend a few years ago just for the hell of it. Unless you plan on running a 406 there is not that much info for the engine. There is however a ton of good info on suspension, fuel system, tires, gears, trans and all of the other little things involved with making a 11 sec f body. The book is based on a large cubic inch budget setup with inexpensive mods just for the strip (i.e. 6 cyl springs, removing sway bars, losing weight......) Hope that is enough info
Old Feb 29, 2004 | 05:39 PM
ponykiller's Avatar
Engine: lo3
Is it worth $20 for 27 pages?At that price I'd almost expect it to change my oil!If it was 200+ pgs I'd have no problem paying it,but 27?C'mon...thats steep!
Old Feb 29, 2004 | 08:18 PM
cgb's Avatar
cgb
I saw this "booklet" a long time ago...
like mentioned, "most" of the info is on suspension tricks.
Pretty sure they bagged it, and used skinny's up front, dropped the front swaybar too...
Terrell351
Jun 13, 2021 01:13 PM
BADNBLK
Nov 16, 2016 09:12 AM
LT1Formula
Nov 16, 2015 01:13 PM
Randomtask2
Aug 21, 2015 10:54 AM
89lsc
Aug 14, 2015 04:58 PM
