Are all SBC created equal?
Old Feb 28, 2004 | 12:54 PM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
what can i take off a 305 and put onto a 400 (block)? (both SBC)
P.S. I have a 400 bare block and a 305 complete engine.
Old Feb 28, 2004 | 01:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can "adapt" just about everything but the pistons.
Old Feb 28, 2004 | 01:03 PM
D M N's Avatar
Engine: 3.4 DOHC
yea but i have a budget of maybe a 250 (which i'm going to use on pistons and rings) i want to use everything off the 305.
ede's Avatar
ede
yeah cost would be the only thing to stop you from using everything but the pistons. maybe few minor things related to 1 piece seal and roller cam 305.
Old Feb 28, 2004 | 01:05 PM
D M N's Avatar
Engine: 3.4 DOHC
so i couldnt use the TPI, Heads, crank, rods, valve train, serpentine belt system, and etc??
Old Feb 28, 2004 | 03:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
IIRC, the 305 crank and the 350 cranks are the exact same, except they are balanced differently. With that being said you would end up with a 377 ci motor i do believe.
Old Feb 28, 2004 | 04:21 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if your going for proformance you wouldnt want that little 305 cam in there.. and if its a roller cam that would make it kinda hard.. you wouldnt want that restrictive tpi setup on it and you wouldnt put stock 305 heads on it.. maybe after some machine work you might wanna put the heads on it as a cheap type of proformance head (larger valves, bowl blending, porting, etc)
Old Feb 28, 2004 | 04:30 PM
D M N's Avatar
Engine: 3.4 DOHC
I dont think you read my post i have almost no money, this is kind of a starting point. In theory with the larger displament (it will end up being 372, i wont have it bored out) means more power then the 305.
P.S. Well after a little math i figure i will end up with 11:1 compression.
Old Feb 28, 2004 | 05:29 PM
85TransAm406's Avatar
Car: 1985 Trans Am
make sure you have the crank rebalanced as the 400 pistons will throw off the balance of the 305 crank, as is was balanced for little pistons.
Old Feb 28, 2004 | 05:30 PM
89RsPower!'s Avatar
thats a lot o compressions for street gas
Old Feb 28, 2004 | 07:46 PM
D M N's Avatar
Engine: 3.4 DOHC
you think? how much compression can be run off of 93 octane fuel?
Old Feb 28, 2004 | 08:05 PM
89RsPower!'s Avatar
thats debateable.. depends on factors like timing, head composition, and valve timing.. thats kind of high for 93 octane in an iron headed engine IMO, I'd try to keep it around 10.1 with iron heads
Old Feb 28, 2004 | 08:07 PM
D M N's Avatar
Engine: 3.4 DOHC
what do you suggest to lower the compression? I cant do anything about the stroke or heads.
Old Feb 28, 2004 | 08:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You can select different pistons. That is the easiest, most common way to adjust the compression. There all sorts of various pistons available. When you buy the pistons, you will notice that most manufacturers give the compression with a 64cc chamber. If the compression is not to your liking, look at a different set of pistons.
Old Feb 28, 2004 | 08:19 PM
D M N's Avatar
Engine: 3.4 DOHC
will flat top pistons work to lower compression
Old Feb 28, 2004 | 08:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
http://store.summitracing.com/partde...2DKB168030%2D8
Those are dished, or reverse dome. 22cc dish. They also offer 30cc dish, which lowers the ratio a bit more.
granted that piston is .030 over, but summit also sells standard sizes. That should be a good street compression. Call them and they will tell you the part number you need.
* Compression ratio: 10.4:1 (58cc heads), 9.9:1 (62cc heads), 9.8:1 (64cc heads), 8.8:1 (76cc heads)
Old Feb 28, 2004 | 08:40 PM
D M N's Avatar
Engine: 3.4 DOHC
9.8:1 compression sound just right (64cc 305 heads)
Old Feb 28, 2004 | 09:34 PM
Car: 1985 Trans Am
305 heads are around 58cc
Old Feb 28, 2004 | 09:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
i forgot about that part.
http://store.summitracing.com/partde...2DKB126030%2D8
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Bradsaundry
Oct 7, 2015 04:35 PM
dusterbd
Sep 29, 2015 08:40 AM
