Brown Oil!! :( Help!
Old Feb 29, 2004 | 01:23 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
I recently purcased a 92 5.7L Z28. When I bought the car I had checked the oil on the dipstick and it appeared fine. The guy said that he had just changed the oil. Now about two weeks later, I checked the oil again and its a goldish brown!! The car does have fairly high mileage (135k) and runs a little rough. Also, the car is 95% stock. Does this mean that there's a faulty head gasket, or worse??!! Please help!!
Old Feb 29, 2004 | 01:33 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
When i think goldish brown i think new oil. Is it the same color as new oil?
Old Feb 29, 2004 | 01:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I doubt theres anything wrong with the head gaskets. If there was, you'd have alot bigger problems.
Sounds like its just in need of a tune up.
Old Feb 29, 2004 | 02:22 PM
incus86's Avatar
Car: 1992 trans am ws6
Engine: l98
Transmission: t-56
i thought oil was that color when it was new...
it turns dark brown/blackish when its old and crappy
Old Feb 29, 2004 | 02:27 PM
No its much darker and brilliant than new oil. He told me it was synthetic that he had put in the car. Since, I ran my 90 Rs 305 on mobil one synthetic for the year that I owned it I can personally say it looks drastically different. Wish I had a digital camera - I would post a pic-
Old Feb 29, 2004 | 04:45 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
As long as it doesn't look 'milky', and the level doesn't go up by itself, I think you should be alright.
Has the coolant level changed any? Does it blow a lot of sweet-smelling white smoke/steam out from the exhaust?
Old Feb 29, 2004 | 10:22 PM
Air_Adam's Avatar
Is it really metallic-looking? like metallic paint?
Old Feb 29, 2004 | 11:08 PM
EvilCartman's Avatar
Car: '82 Z28
Does it look like coffee after you pour milk/creamer in? if so you have problems. If it looks like honey, you should be fine unless you have a metallic honey look lol.
Old Mar 1, 2004 | 05:47 AM
ede's Avatar
ede
if you're worried about the condition of the oil send a sample out to be tested. it's pretty cheap and easy to do.
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
tattmann
Sep 27, 2015 05:20 PM
