What Kind Of Spark Plugs?
Old Feb 29, 2004 | 08:42 PM
C_A-Formula350's Avatar
Car: 1991 Formula 350
What Kind Of Spark Plug Wires?
hELLO I HAVE A 1991 FORMULA 350 AND I WAS WONDERING WHAT SPARK PLUG WIRES I SHOULD GO WITH. i RECENTLY REPLACED THE CAP AND ROTOR AND NOTICED A FEW OF THE WIRES WERE CORODED AND LOOSE ON THE CAP. I ALSO REPALCED THE SPARK PLUGS. i AM A LITTLE CONFUSED WITH ALL OF THE ONES ON THE MARKET. ALSO IS THERE REALLY A NOTICABLE DECREASE IN PERFORMANCE IN 7MM WIRES?
ALSO THE ENGINE HAS BEEN RUNNING A BIT ROUGH IT SOMETIMES STALLS OUT AND THE RPMS KINDA GO UP AND DOWN A BIT (INSTEAD OF IN GEAR IDLING AT 700 IT GOES ALL THE WAY DOWN TO 500 AND BACK UP) I LOOKED FOR VACUME LEAKS AND HAVE NOR FOUND ANY
THANKS
Old Feb 29, 2004 | 09:31 PM
MdFormula350's Avatar
i like a/c delco rapid fires for plugs.
and i use accel 8.8's plug wires. since i needed 90 degree boots for my header install.
trying running a search on difference brand names like a/c delco msd taylor accel bosch to see what others think / use.
i tend to buy tune up parts that are in stock at my local parts store for a good price.
stock oem size wires should be fine to use with stock ignition / engine setup's.
Old Feb 29, 2004 | 10:24 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I run AC delco R45TS spark plugs in my 350. And I also run 8.8 accel wires because I also need all 90 degree boots for my headers.
I would go ahead and change the wires it definetly won't hurt anything.
Old Feb 29, 2004 | 10:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Pretty much any wires you go with will be an improvement over stock. You won't hear many complaints from any particular brand.
Old Mar 1, 2004 | 01:58 AM
OMINOUS_87's Avatar
NGK for plugs, you can find them at NAPA.
Old Mar 1, 2004 | 05:45 AM
ede's Avatar
ede
try pressing the cap lock button, things will work out a lot better.
Old Mar 1, 2004 | 10:40 AM
he's new let him stay
Old Mar 1, 2004 | 04:24 PM
aha didnt mean to offend anyone with the CAPS lock on but what the heck a quesiton is a question no matter how it looks.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
