oil leak... need input
Old Mar 2, 2004 | 12:16 AM
dangerousd89's Avatar
Car: so many projects to little time
Engine: 350 tbi
I recently changed my intake on a 350 tbi. Now i have an oil leak. The truck can stand all day at idle and no leak. As soon as i drive it it leaks when i park. It only leaks under load. I checked the oil pressure sending unit that screws into the back of the block and it was fine. I think maybe i didnt put enough rtv gasket silicone on the back of the intake and block mounting surface. What do you guys think... Any help will be appreciated
Old Mar 2, 2004 | 12:28 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: oil leak... need input
I think you answered your own question.
Old Mar 2, 2004 | 05:15 AM
ede's Avatar
ede
takes less than 1/4" bead of rtv to have enough to make a seal. if you think that's the problem fix it and see if the leak goes away
Old Mar 2, 2004 | 07:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, I'd start there as far as guessing.....
Or, rather than guessing, take the car to the quarter car wash, and sterilize the motor; then drive it for a couple of minutes; and stop and get out and look at it and see where there's fresh oil.
Old Mar 2, 2004 | 08:21 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Sounds like the china wall to me. Mine used to do the same thing. I pulled the intake and resealed the china wall and the leak stopped. I think thats probably your problem as well.
Old Mar 2, 2004 | 12:17 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
china wall?
Old Mar 2, 2004 | 12:26 PM
Originally posted by Meatikis
china wall?
The two small gaskets that go on each end of the intake are called china wall gaskets. Thats what those two openings are referred as, china walls. Some people use the gaskets and some dont. I am one who doesnt. Just gotta make sure you use enough RTV.
Old Mar 2, 2004 | 10:17 PM
Transmission: 4l60e
I just use RTV also. Always works for me.
Old Mar 2, 2004 | 10:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Isnt there that little cirlce gasket around the base of the dizzy, too?
Old Mar 3, 2004 | 12:51 AM
yes...
Old Mar 3, 2004 | 06:01 PM
Meatikis's Avatar
Car: '86 Z-28
first time i took it out, it didnt even have one on there. maybe it fell off when i pulled it out, cause it's never leaked..
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
tyeo098
Nov 30, 2015 06:27 PM
customblackbird
Oct 1, 2015 04:30 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
