DIstributor changing questions??
I am changing distributors on my car it is in a computer controlled quadrajet car which i am changing the carbs to but I was wondering how to hook up the vacuum advance distributor. How do I hook up the wires for it?
thanks
thanks
Car: 4
Engine: 6
Transmission: 5
All it needs is power and tach. The big pink wire from the harness goes into the "Batt" spot, and the tach wire (white? goes to the filter mounted on the firewall, little siver can) goes into the "Tach" hole.
ICON Motorsports
ICON Motorsports
Car: 4
Engine: 6
Transmission: 5
You plug them in. Put your dykes away, you don't need them when you're working on a car.
At worst, you might have to crimp a different connector on the end of the wires. Which kind of distributor do you have now?
ICON Motorsports
ICON Motorsports
Car: 4
Engine: 6
Transmission: 5
What kind of distributors do you have? the small one with the separate coil, or the large one with the coil in the cap?
ICON Motorsports
ICON Motorsports
Car: 4
Engine: 6
Transmission: 5
The plugs are identical in every way. Just plug it in.
Ignore the 4-pin Weatherpack, it's part of the computer.
ICON Motorsports
ICON Motorsports
