I thought stainless steel headers weren't allowed to rust?
Old Feb 13, 2001 | 02:41 PM
crazeinc's Avatar
Hi guys. I picked up some SLP 1 3/4" shorties along w/ the y-pipe but they're not shiny...more of a rust color...can I just polish them up? what caused this? what do you reccomend to make them look nice again?
1982 Camaro Z28
should be running 11's this spring...we'll see
Check the website for progress http://members.fbody.com/Pro82Z/
Old Feb 13, 2001 | 02:57 PM
Guest
Guest
Posts: n/a
Not all stainless doesnt rust. The stuff they use can get surface rust, but nothing major. I have heard of people just polishing them up.
Old Feb 13, 2001 | 03:27 PM
theformula's Avatar
The SLP headers come in 409 Stainless steel (unless specified 304). 409 is good because it is cheaper than 304, but has identical wear properties. 304, doesn't show surface rust. Thats why SLP uses 409 for the intermediate pipe and over axle pipe in their catback package, and 304 on the muffler and tailpipes. Madmax is right, the only rust you really get with the SLPs headers is surface rust. I would sand them and paint them with VHT manifold paint followed up by their hot temp clear coat. Both available from Summit.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 13, 2001).]
Old Feb 13, 2001 | 03:30 PM
theformula's Avatar
Another thing. If you polish them, more than likely they will return to their original state.
Best bet is to paint them. My friend's GTA had glass beaded SLPs turn brown after 15minutes.
Old Feb 13, 2001 | 04:13 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
hehehe, bet you wish someone would have told you BEFORE you installed them b*tches now huh?
Old Feb 13, 2001 | 07:53 PM
crazeinc's Avatar
actually, I was fortunate enough to get them in their brown state before installing them so I picked up a few cans of 1500* paint and sprayed them...hopefully tomorrow I'll grab another spark plug (my friend decided to break one) and I'll bolt up these headers and y-pipe and see how the motor sounds. Hopefully then I'll get a catback sooner than later.
Oh yea...with so much of my engine bay cleared, installing headers literally only takes 5 minutes at the most so it's no biggie.
[This message has been edited by crazeinc (edited February 13, 2001).]
Old Feb 13, 2001 | 11:58 PM
JPrevost's Avatar
Car: 91 Red Sled
Mine have surface rust, I like it. Makes engine look more stock so when I pop the hood everybody thinks nothing's been done. I like the sleeper look, do everything under the skin so to speak. Upgrade from inside out. Good luck with the painting, I've heard that it isn't worth it. What about header wrap? Anybody think that's a good idea?
, Jon (91 RS too many mods to list), getting new engine in summer
Old Feb 14, 2001 | 04:38 AM
theformula's Avatar
Header wrap=under the hood fire
Old Feb 14, 2001 | 08:55 AM
Kenn's Avatar
fire lol
my tes headers have been wrapped since Nov97 and they havent flame me - I did have a fire though at start-up - Vacuum leak caused high exhast temp lead to glowing red collector catches O2 sensor wire on fire and still the wrap flamed not
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
