Aftermarket Electric Fan
Old Feb 13, 2001 | 03:54 PM
JOEMAROZZ4's Avatar
I have an 84 Z28 with a ZZ4, and I want to get rid of the power robbing flex fan I have and get an electric fan. Has anyone done before and if so did you go with one fan or two?...pusher or puller or both? How did you mount it? Pictures would be great.
Thanks - Joe
Old Feb 13, 2001 | 03:57 PM
84TransAm's Avatar
I think it is just pushers unless you have a/c then it is pusher/puller. I have looked into this before but decided to pull the assembly off of a later model Firebird at the junkyard. Takes a lot of guesswork out and is cheaper than new.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Old Feb 13, 2001 | 04:04 PM
JOEMAROZZ4's Avatar
Thanks Steve...I was thinking about that.
I don't have A/C...I'm thinking I still want to go with an aftermarket unit if I can..otherwise I'm taking a trip to the junkyard like Steve
Joe
Old Feb 13, 2001 | 04:15 PM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
The best electric fans are made by Spal. The fans made by PermaCool and Flexalite are rated in free air, and when installed behind a radiator do not perform as rated.
1982 Corvette Tremec TKO
<A HREF="http://www.geocities.com/monty_williams/434specifications.html" TARGET=_blank>SBC 434 700hp/600tq
</A>
Old Feb 13, 2001 | 04:18 PM
JOEMAROZZ4's Avatar
Monty - How do I get intouch with Spal?
Do they have a website? I take it you have one of there fans.....how do you like it?
Old Feb 13, 2001 | 04:20 PM
R.O.B.'s Avatar
Keep in mind. Pusher is for in front of the rad, Pullers go inbetween the rad and engine.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 13, 2001 | 05:53 PM
The ODB's Avatar
Best performers are GM factory large diameter single electric fans like the ones on 85-86 Irocz. Fans are much more efficient in the pulling mode behind the radiator. Be sure to get the large airdam from the newer Irocz as well.
ODB
Old Feb 13, 2001 | 06:31 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Spal makes the best electric fans on the market. www.spal-usa.com
The puller set up is much more efficient.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Feb 14, 2001 | 12:28 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Anyone happen to know off hand what they charge as a general rule for the Spal fans, just a common size like 12" or 16" ers?
Don't see any prices on their site, but most aftermarket fan setups I've seen have been pretty darn high for a broke bum like myself. I think my stock dual fans are about dead so I'll need to do something before spring...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Feb 14, 2001 | 10:18 AM
Monty's Avatar
I don't know what a single fan costs, but I have been using the Spal High Performance Dual 11" fans with integrated shrouds. They cost me $259, but they will keep the coolant temp at any temperature I set them to come on at, no matter the ambient temp or driving conditions.
</A>
Old Feb 14, 2001 | 10:59 AM
JOEMAROZZ4's Avatar
Monty - What part # do you have?
Do you have any pictures of the fans
installed? They have 7 or so part #s
for the 11" fans.
Thanks,
Joe
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
gta892000
Sep 16, 2015 12:37 AM
