what is a code 13?
Old Mar 4, 2004 | 04:22 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what is a code 13?
Just pulled a code 13.. what is it?
Old Mar 4, 2004 | 04:31 PM
llvll4l2c91350's Avatar
oxygen sensor circuit is open
Old Mar 4, 2004 | 04:34 PM
89RsPower!'s Avatar
would that indicate a bad 02 sensor? the circuit is complete and check out ok.. thanks!
Old Mar 4, 2004 | 04:39 PM
yup one cause for code 13 is a steady signal stuck at about .50 volts. has it been changed at all before?
Old Mar 4, 2004 | 05:14 PM
89RsPower!'s Avatar
thats anybodys guess..
Old Mar 4, 2004 | 06:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can also get a code 13 from a throttle position sensor being set too high.
Old Mar 5, 2004 | 10:20 AM
89RsPower!'s Avatar
maybe i should say what the car is.. its a 83 carbed l69
Old Mar 5, 2004 | 06:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The TPS adjusted too high would still apply. It is located inside the carburator and has a connector with three wires going to it. I had the same problem on a 1985 5.0L with a 4 BBL.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
