Anyone who has done AC/smog pump delete!
Car: 90 Camaro RS
Engine: 305 TBI
has anyone removed the smog pump and/or ac. if so..i would like to know what route you used and what size belt. and what results you experienced. thanks guys.
Rick
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Rick
Rick
There is a tech article here on thirdgen.org that explains how to route the belt and what size to use after you remove the smog pump. Or, you can install a smog pump delete pulley in place of the smog pump and keep the stock belt and routing. You can read about (and see pictures of) the smog pump delete pulley here and here.
Forgot to mention, there is also an A/C delete pulley as well. 1LE's got them since they did not get A/C. Sorry, don't have a part number for that one though. So if you got the A/C delete pulley and the smog pump delete pulley you could keep your stock belt and routing without having A/C or the smog pump.
first thing to do is if your a/c still works fo to a place that can take the freon out.. then i just started cutting the a/c lines i took everything out including the heater core and everything. i even took the box out i used a aluminum plate to cover up teh fan box hole and condensor hole. also u can take the condensor out of the front of the radiator. that helps free up some cold air to the radiator.. the belt number u need is 786k6 see if seanaullivan still comes to this board if he does he has a diagram on how to route the belt its pretty self explanitory though and that belt number is for the use with the 3 pc underdrive pullies so if u need anything else try to get ahold of him he helped me alot. hope this helps good luck!!
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
thanks sean knew u would come through!! i knew u knew how to do it and i didnt have the pic anymoe that u sent me so i sent him your way!! hope that helped u out there man
BlackphantomZ28
Aug 21, 2015 07:12 PM
