how do you remove the shifter knob?
Old Mar 7, 2004 | 10:24 AM
Z28Clone's Avatar
how do you remove the shifter ****?
How do you remove the leather shifter boot? I cant get the shifter **** off to remove the boot. Is the **** pressed on or threaded? Any ideas?
Old Mar 7, 2004 | 10:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
On a manual transmission, the **** twists off.
JamesC
Old Mar 7, 2004 | 04:36 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
On my automatic transmission, I seem to recall there being a small black metal staple in the front center of the leather boot that had to be pulled out with a needle nose pliers. Then the boot/**** piece pulled straight up.
Old Mar 7, 2004 | 06:41 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Staple in front
Both are right. I assume it's an auto because the manual is pretty simple to figure out.
I used a small screwdriver to coax out the long staple looking thing. It is on the front side of the shifter handle, (towards the radio) about 1/2 inch or so from the bottom. It's kinda hard to spot with the leather, but it pulls straight out towards the engine and the shifter will pop straight up.
Good Luck
Troy
So Cal
Old Mar 7, 2004 | 06:53 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Here's a pic of that staple clip
Old Mar 7, 2004 | 08:16 PM
JamesC's Avatar
According to Z28Clone's sig, he's running a T-5.
JamesC
Old Mar 7, 2004 | 08:24 PM
Car: 89 RS
Ok. Should be a twist off ****.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
