stuck starter solonoid?
Old Feb 12, 2001 | 06:43 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
The other day I got into my car, and when I tried to start it up, it slowly cranked. So I turned off the ign., and removed the key, and the car kept cranking. It cranked until it the battery died. I remember in shop, something about this happening, but could I be wrong? I am having back troubles, so I can't just get under there and check it out, otherwise I would. But since I need to change my starter to the manual, it doesn't matter too much. But I would like to atleast turn it around to face my garage, so when I do the engine, and tranny swap, it will be easier. Any thoughts?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 12, 2001 | 08:18 PM
Eggplant Jeff's Avatar
Sounds like maybe the solenoid shorted against something? Or the ignition switch did.
If you can't get it figured out, get a couple of friends (with good backs) to push the car into the right spot :-).
Old Feb 17, 2001 | 06:01 AM
stingerssx's Avatar
Thanks, maybe I'll just have to do that, or just leave it where it is.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
