cam
Old Feb 16, 2001 | 10:25 PM
sonnyb's Avatar
cam
I recently removed the tpi system from my car, I am going to port the intake and plenun before I reinstall the tpi system. My question is the cam which is a comp roller #08-304-8 with duration at .050, 210 intake, 220 exhaust, intake center line 110 and lobe separation 114. Will this cam cause my computer problems or should I revert back to the stock cam or just get a more computer friendly grind?cam
Old Feb 16, 2001 | 10:52 PM
82z's Avatar
82z
I don't think you will have a problem with the revatively tame duration numbers and the wide lobe seperation angle.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 17, 2001 | 10:19 AM
Beefy89's Avatar
You might want to get a cam with an lsa of 112 or better,but I have seen posts on this board in which the lsa was 112 or less.
We need Perry Mason
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
