Proform roller rockers, has anyone heard of these?
Old Feb 14, 2001 | 05:17 PM
MrJ's Avatar
MrJ
Someone on here mentioned them a while back. Supposedly, they are only $140, are available in 1.6 ratio, and will fit fine under centerbolt valve covers. Anyone know what I'm talking about?
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Feb 14, 2001 | 07:50 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yea
I think I was one of the ones asking that question in the post you mentioned.
so whats the deal people.
especially the 1.6 ratios.
anyone use them on self aligning apps??
Old Feb 14, 2001 | 10:00 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'm using them for 8000 miles so far... no probs. I have guide holes though and not using self-aligners. The fit under center bolt covers with a little 'massaging' of the oil baffle for the pcv (Just smash it in a little with a LFH)
Old Feb 14, 2001 | 11:14 PM
MrJ's Avatar
MrJ
alright cool.... where did you get them? And were they really $140? Are they full roller or roller tip?
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
Old Feb 14, 2001 | 11:51 PM
Basett Racing's Avatar
Jeg's has them , and the regular style is $149.99, but the self aligning style is $169.99. They are a fully machined full roller rocker. A friend of mine has a set of the regular style 1.6's on his car and has been running them for over a year w/ no problems. They appeared to be a nice, high quality rocker from looking at them, and they operated very smoothly by hand.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Feb 15, 2001 | 12:00 PM
MrJ's Avatar
MrJ
2 questions
1) there are several versions of these available, but only a couple in 1.6 ratio. Which of these fits an 87+ 305 or 350 TPI?
2) What is the effective lift with these installed? I'm sure someone must know what the effective lift of an L98 cam with 1.6 rockers is.
Old Feb 15, 2001 | 09:15 PM
JoelOl75's Avatar
I'm not sure of the answer to question #2, but let me see...
SBC 1.5 3/8
SBC 1.6 3/8
SBC 1.5 7/16
SBC 1.6 7/16
SBC 1.5 3/8 Self-Align
ect...
First don't automatically assume you need self aligners. Take your valve covers off and make sure you don't have any pushrod guides. I have an '88 and had them but some people I know have '88's w/o them and needed self-aligners. I think this was the X-over year. I got mine through jegs, and while your at it, why not get their "street screw in rocker studs" I installed them with the heads on the car. Actually I changed the springs, retainers, and keepers and tapped the stud holes with the heads on the car (I really didn't want to take 'em off) Just get an air hold tool to keep the valves up. And put towels down in the intake if you take it off. Ooops. I forgot, you have to take the intake off to make sure to catch all the chips that come down into the intake port. The exhausts are into coolant jackets. I just took a 7/16-14 tap to 'em. It's amazing how little of force it takes to pull the pressed in studs out! So I don't regret going through the trouble. The street screw in's are made by mr gasket and have a small shoulder for jamming them requiring no machine work to the boss (for the large hex). Put sealer on the threads and using two nuts jam 'em to abouts 40 lbs/ft. Make sure you get all the metal chips. I used a piece of cardboard covered in axle grease. If you accidentally drop some in just push down on the intake valve with the air on that cyl and they'll blow right out. Into the lifter valley if not careful. This may be a little more info that you care to hear about but pressed in rocker studs scare the hell out of me. Especially with high lift and 1.6's.
If you have guide holes get the SBC 1.6 3/8
If not get the SBC 1.6 3/8 self-aligning
Make sure to check this. Also is you have guide holes and goto 1.6's check for bind in the guidhole (1.6 ratios move the pushrod closer to the valve) Mine were OK but I heard stories that involved clearancing.
Good luck!
Old Feb 16, 2001 | 01:11 AM
Mr J, Take the gross advertised lift of the L98 and divide it by 1.5 The take the number you got from this and multply that by 1.6
I'm don't know what the stock L98's lift is, but here is an example of how to figure it, if you know it.
.450" / 1.5 = .300"
.300" X 1.6 = .480"
Bassett Racing
[This message has been edited by Basett Racing (edited February 16, 2001).]
Old Feb 16, 2001 | 10:27 AM
The ODB's Avatar
I have a set of 3/8" Proform 1.6 ratio rockers in my closet right now. They are very sloppy in the bearing areas of both the fulcrum and tip. They work fine but are more noisy than others.
I switched to Harland Sharp which are the best quality rollers I've seen yet.
ODB
Old Feb 16, 2001 | 10:42 PM
JoelOl75's Avatar
Mine were nice and tight. How can they be noisy when your running zero (hydraulic) lash???
Old Feb 16, 2001 | 11:39 PM
burnoutrpm's Avatar
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
ODB
</font>
im with ya! harland sharp rule!!!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 16, 2001 | 11:42 PM
burnoutrpm's Avatar
the proform stuff is of good quality i just purchased the ho proform hei vac advance disributor. i decide on this distributor because my frined bout one for his 406 roller and it made a great difference and the price of theyre things cant hardky be beat! but for even better quality go with the harland sharp rolers just better quality!!!!
Old Feb 17, 2001 | 08:34 AM
bad camaro RS's Avatar
i feel as though proform brand are very cheap a bought thier tach and when i hooked it up it started smoking "yes i hooked it up right" the guy at jegs said alot of thier stuff gets returned so i bought an autometer tack and love it so now i stay away from proform jus my opinion
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hopeing for 12's
Old Feb 17, 2001 | 09:40 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Proform is a perfect example of "you get what you pay for"...or maybe "buyer beware"
Is it really worth saving a few bucks on roller rockers....I look at it this way, how much does an engine rebuild cost after one of those rollers decides to spit it's internals out and circulate it through the motor? Just a thought
Old Feb 17, 2001 | 10:23 AM
very well put 406tpi spend the few extra bucks for relability
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
