How much oil do I put in differential?
Old Feb 17, 2001 | 03:03 PM
HIX5000's Avatar
Should I just fill it up to the set screw on the side?
1988 Camaro RS
2.8L five speed
Money pit from hell!!
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Feb 17, 2001 | 03:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. Fill it up to the level of the fill plug. It should take betwen 1½ and 2 quarts. Then drive it slowly around a bunch of corners in a parking lot or something, turning bothe ways, to sling some fuid up into the tubes.
ICON Motorsports
Old Feb 17, 2001 | 03:08 PM
Vader's Avatar
HIX,
Yes, it will take a little less than two quarts on a Saginaw (now American Axle) ten-bolt housing. If it has a limited slip axle, mix the friction modifer additive with the first quart before you pump it in.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 17, 2001 | 03:09 PM
HIX5000's Avatar
Thanks guys
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
