UD pulleys
Old Mar 11, 2004 | 02:41 PM
camaro88sc's Avatar
Car: 1988 Chevy Camaro SC
Engine: 305 TBI
UD pulleys
what kind(brand, etc.) of underdrive pulleys should i get? i have an 88 camaro 305 TBI
Old Mar 11, 2004 | 03:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will get better answers and opinons here. I would try a search first though. This topic comes up quite a bit.
Old Mar 11, 2004 | 03:33 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I don't mind answering this question. Since everyone always sends you to the search button on this site. I personally like the March Pulleys. I have used the V Belt ones and the Serpentine ones and both work great. The quality is great. No problems with the alternator either.
Old Mar 11, 2004 | 03:35 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
https://www.thirdgen.org/techbb2/sho...rdrive+pulleys
I found those 3 w/ a 30 second search...
Old Mar 11, 2004 | 04:19 PM
TA5LiterHO's Avatar
The whole point here is that this is a message board and not a reference library. It's not that hard to answer his question. All he's asking is other peoples experience and what they suggest. If he wanted info on what pulleys would fit his engine he could just look on Jegs or Summit.
Old Mar 11, 2004 | 04:41 PM
camaro88sc's Avatar
Engine: 305 TBI
TA5LiterHO thanks you for your responce on my question, and thank you for understaind that its not really that hard to answer. thank you for your help
Old Mar 11, 2004 | 05:10 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
camaro88sc,
Don't know where you are from, but if you are in a hotter climate, be sure not to slow down the water pump too much.
Old Mar 11, 2004 | 09:58 PM
TA5LiterHO's Avatar
As long as you aren't running a mechanical fan you should not have a problem with overheating unless you get an overly small crank pulley.
Old Mar 11, 2004 | 10:18 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
so with underdrives...you want a the smallest ALT pulley you can get?
THe one that came with my set was bigger......the stock ALT size is 2" 3/8ths and the one I got was 2" 7/8s...I put the stock one back on cause the diode switch in the ALT went bad, I dotn know the pulley caused that or not...but it seems to be charging fine with the stock one back on it...
Old Mar 12, 2004 | 10:06 AM
TA5LiterHO's Avatar
I left the stock pulley on my alternator because I just never got around to changing it because the bolt is frozen on. They are both the same diameter, so I never bothered trying again.
Old Mar 12, 2004 | 11:49 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
With a bigger pulley, the accessory will be driven slower..
Old Mar 12, 2004 | 05:35 PM
should I put my bigger one back on? or just leave the stock one?
Old Mar 17, 2004 | 01:22 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
The reason why the alt. pulley is larger is because its actually an overdrive pulley.
When you buy an underdrive pulley set like crank, water pump, and alternator, the alt pulley will be bigger to prevent charging problems. It compensates for having the other stuff underdriven.
Old Mar 17, 2004 | 01:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I personally like ASP pullys
If you are a fully powered option car, large radio system, I personally dont recommend the alt pully.
I live fairly far in the south, and do not have overheating problems. I have put them on every ride I have owned in the past 6 years.
Whoever cant get the alt pully off, use an impact while the alt and belt are still attached to the car, then remove belt, then pully, put pully back on as tight as your fingers allow, then belt, then impact.
Old Mar 17, 2004 | 02:01 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I have the March pulleys and they work great. I left the stock altenator pulley on.
Old Mar 17, 2004 | 02:06 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i'd go with the march crank pulley. dont worry about the alt pulley... i dont think it's worth it for only about 1-2 hp
Old Mar 17, 2004 | 10:44 PM
will it screw up my alt if I put the big pulley back on? or should I order the 2 "1/8 polished one from March? I just want all my pullies to look the same.
Old Mar 18, 2004 | 12:37 AM
TA5LiterHO's Avatar
Putting the bigger pulley on your alternator should save it some work.
Old Mar 18, 2004 | 01:44 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
You can run the bigger pulley. If you have a bad a$$ sound system the pulls a lot of current you may have some issues with the battery not getting a good charge.
Old Apr 4, 2005 | 02:14 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
Just bought the ASP crank pulley and corresponding belt to fit. Just wondering if there is a set amount of torque that needs to be applied to tighten the new pulley back up. Or is it just tighten till you can't anymore?
Old Apr 4, 2005 | 11:28 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
if you decide to go with march,keep an eye on ebay,i got crank,alt,water pump,and power steering WITH all brackets and bolts,in silver powdercoat(nicely understated!)for 200 bucks shipped!
just make sure you know the part #s needed.check march's site for them.
Eric B
Old Apr 5, 2005 | 01:32 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
How much gain to get from the pulley sets? Is it noticable? I've looked at them, but don't know anyone that is running them.
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
