This will leave you scratching you're head.(NEED HELP!)
Old Mar 11, 2004 | 05:07 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Alright guys this is what we got.
305 H.O. motor
Anti-freeze in oil.
Head Gaskets are fine.
We got smoke, oil and dope mixed coming out the tail pipes.
Heads look okay.
But, fouling plugs.
Block Looks fine.
No cracks anywhere.
So what do yall think? rings are bad?
This thing has been rebuilt, and it's not been rebuilt long. There is no ring wear at the top of the cylinder what-so-ever which is something I myself have never seen or heard to tell of.
On the gaskets I can't see anywhere were im loosing comp.
Do you think some dumbass just didn't ring the pistons?
I'm so confused with this guys. And I can get pics of the heads and gasket if that would help yall.
Any idea's?
-Jensen
Old Mar 11, 2004 | 05:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Anti-freeze in oil
Rings can't possibly do that. Forget them.
You have either a bad intake gsket; bad head gasket; cracked head or block, or intake; or you didn't put sealer on the head bolts or rocker studs.
Old Mar 11, 2004 | 05:20 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Have you looked at the intake manifold gaskets as the culprits?
Old Mar 11, 2004 | 05:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sounds more like a hair line crack that was either missed at build-up or just occurred from a weak spot. Either way, with anti-freeze in the oil, you need to get it out fast or replace the whole Kaboodle.
Old Mar 11, 2004 | 08:19 PM
I cant find ANY cracks....ANYWHERE....ive cleaned and cleaned...and found nothing...
so would yall just seal it all back up and run it and see what happens?
Old Mar 11, 2004 | 08:26 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I`d look at the intake valley real close, right under the bolt bosses for the heads, sometimes these cannot be seen with your eye and need magnafluxing to see. did the coolant mix occur fast or over time? Does it have a oil cooler? more info!
Old Mar 11, 2004 | 08:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Like greezemonkey says, to properly check your engine or anything for cracks you would need to either x-ray or magnafux it. You could have an engine that doesn't appear to have any cracks, but once the engine warms up and you get some pressure built up they will appear.
Old Mar 11, 2004 | 10:12 PM
No oil cooler, over time im sure.
I did not build the engine...it came in one of my cars...I would never build a 305....lol
I'll take another gander at the lifter valley tomorrow...the engine is out so anything else yall can think of just tell me and i will check...
if i cant fix it...hell ill throw a junk yard 350 in.
Old Mar 12, 2004 | 05:15 AM
ede's Avatar
ede
have you mag or penetrante tested? had the block and heads pressure tested? i'd start with PTing since i could do that at home and the take it to a shop for pressure testing. might want to try a combustion gas tester too.
Old Mar 12, 2004 | 01:56 PM
How would I go about doing a pressure test?
Never done that don't reckon.
Thanks again
-Jensen
armybyrd
Sep 28, 2023 12:16 AM
Eric-86sc
Feb 25, 2016 09:02 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Royal_Z
Sep 30, 2015 08:45 PM
