Help with brass fittings?
Old Feb 18, 2001 | 05:06 PM
89GTA5spd's Avatar
I am trying to hook up a NOS setup with brass fittings.
I need to connect 2 brass lines with a T to split the initial nitrous flow.
Anyway.. i have to cut the brass pipe to length, and I have these rings that fit around the pipe that I am supposed to attatch to the brass pipe where I want to end it so I can put the thread on it. I have no idea how to connect these "rings" to the pipe.. does anyone with any knowledge of this kind of stuff know?
thanks.
Old Feb 19, 2001 | 12:12 AM
Guest
Guest
Posts: n/a
Im taking a guess here... but is there a ring, and then you have a part that has a threaded end, and something that looks like a nut? Well if thats it, then the ring goes inside the nut, and you screw that on one end of the threaded deal. The brass line will fit inside the nut, and then you tighten the nut down. Its called a compression fitting. Im not sure if thats what it is, but it sounds like it. Cant imagine a NOS system using that though, compression fittings arent the most reliable things on the face of the planet.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
