redline waterwetter
Old Feb 17, 2001 | 04:44 AM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
redline waterwetter
Has anyone tried this products? Claims to reduce coolant temp by 30 degrees? Also lookin into a stewart water pump.
Old Feb 17, 2001 | 08:37 AM
ede's Avatar
ede
it works ,maybe not as well as they claim, all depends on the condition of your cooling system. royal purple makes something too, forget what it's called.
ICON Motorsports
1st & 3rd
Old Feb 17, 2001 | 11:06 AM
Havoc's Avatar
The stuff from royal purple is called purple ice. It seems to work decent, I'm running it my car.
Old Feb 17, 2001 | 02:30 PM
CrazyRob75's Avatar
The thing with water wetter is it works better in exactly that, WATER. Straight water actually helps dissapate heat faster, but of course it freezes, rust etc. Antifreeze prevents freezing, provides corrosion protection and lubritcation. If you are running a 50/50 mix in a car that doesn't run hot, you won't see a difference. In a combo like mine with mostly water in the system (roughly 85% distilled water 15% antifreeze, after winter of course!) a bottle of WW will help reduce temps. Keep in mind this is not a cure for a malfunctioning cooling system.
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Old Feb 17, 2001 | 08:19 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by CrazyRob75:
...If you are running a 50/50 mix in a car that doesn't run hot, you won't see a difference.... with mostly water in the system... a bottle of WW will help reduce temps. </font>
RD WW does work rather well. It will also reduce temps in a 50/50 mix as well as in a water dense mix. Personally, I always recommend 60/40 mixes.
"Perfection is a trifle dull. It is not the least of life’s ironies that this, which we all aim at, is better not quite achieved."
-W. Somerset Maugham
Old Feb 18, 2001 | 02:14 AM
CrazyRob75's Avatar
I agree a roughly 50/50 mix is better, but that would be on a street driven, year round daily driver. Mines a summer car, so I run a weaker mix. I find I get cooler, more consistent temps. by running more water. I find that the WW is MORE effective with a higher water content. When I tried it on my 305, I noticed no difference, on the BBC, I do notice a reduction in temps. This is just my results on my car, every car and climate conditions will be different. All I'm saying is to NOT use this on a weak or failing cooling system as a crutch. This is the same as putting thicker oil in to reduce oil burning or putting sawdust in the diff. to queit it down. None of these REPAIR the problem, they just MASK it for a while. So, use this as a SUPPLEMENT not a CURE for the cooling system.
Old Feb 18, 2001 | 11:37 AM
The ODB's Avatar
It increases the heat absorbtion rate of your coolant. That means it will lower the temperature of the metal (coolant passages), NOT your coolant temperature.
Do not expect to see temps on your gauge to drop any at all.
ODB
Old Feb 19, 2001 | 10:41 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
ODB
</font>
It actually increases the heat transfer rate of water and slightly does this for ethylene and propylene glycol. It will reduce your operating temps.
"Only in Britain could it be thought a defect to be “too clever by half.” The probability is that too many people are too stupid by three-quarters."
John Major
Old Feb 19, 2001 | 12:26 PM
355 IROC-Z's Avatar
WW is suppose to protect againtst corrosion and rust. i did notice a difference in temp in mine since i rarely had to use my second cooling fan.
HikoriYami
Sep 21, 2015 07:11 PM
sunbitz
Aug 14, 2001 12:56 AM
sunbitz
Jun 27, 2001 09:31 PM
vadrad
May 26, 2001 07:01 PM
matty350TPI
Aftermarket Product Review
Nov 19, 2000 06:41 PM
