Cast Iron or Aluminum Heads
Old Mar 12, 2004 | 06:34 PM
1982Camaro383's Avatar
Question for you guys, I have a 1982 Camaro and going to build a 500hp 383 engine. I would like to go with aluminum heads for weigt, cooling and power but if the engine overheats once your screwed do to warping. So i was thinking cast iron which cast iron head should i use to make good power and flow for a 500hp 383. Any help would be greatly appreciated.
Thanks,
Justin
1982 Camaro
http://www.fbody.com/members/82Camaro
Old Mar 13, 2004 | 05:36 AM
ede's Avatar
ede
cast iron warps too if you over heat the engine. i don't think i'd limit my options on something yuo shouldn't allow to happen any way. also a warped head is repairable.
Old Mar 13, 2004 | 07:36 AM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
I agree, as long as you've managed your cooling system,
you shouldn't have that hanging over your head.
As far as head choices I went aluminum over cast iron.
Needed that lightweight for intentional racing purposes,but cast iron heads also have advantages over aluminum so...
It's basically a matter of YOUR choice.DUECE
Old Mar 13, 2004 | 12:54 PM
My car has only overheated once due to a thrown belt, since then I switched to a March Pulley system, cast iron headers and had a custom aluminum radiator with large fans installed and has never overheated since came close once driving in the woodward dream cruise. Which heads should I use on a 383 500hp engine, that will be used for the stip and used as my toy on the weekend.
Thanks,
Justin
1982 Camaro
Old Mar 13, 2004 | 01:04 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
out of curiosity who makes headers out of cast iron and why would you make headers out of cast iron?
Old Mar 13, 2004 | 01:35 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
i think he ment cast iron heads
Old Mar 13, 2004 | 01:43 PM
89RsPower!'s Avatar
oo that makes more sense.
Old Mar 13, 2004 | 01:56 PM
Sanderson makes the cast iron headers they dont burn off a ton of heat like tube style headers www.sandersonheaders.coms. I was referring to heads though. I was thinking AFR 195's or Pro Topline Lighting 23 degree. Gonna be used on a 383 500hp engine. Looking for ideas.
Thanks,
Justin
1982 Camaro
junkcltr
Aug 2, 2019 11:12 PM
Chuck84TA
Jul 15, 2016 09:05 PM
anesthes
42
Oct 24, 2015 07:30 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
