do i need a new throttle body?
Old Mar 13, 2004 | 02:59 PM
RaMaiRGoD69's Avatar
Car: 88 GTA
The situation: I have 88 GTA w/ Lt1 Afr 195s port matched to the intake manifold 30 lb injectors comp xtreme energy cam 224 duration 535 intake 550 exhaust 1.6 to 1 roller rockers headman shortie headers K&N filter flowmaster american thunder exhaust 2400 stalll speed and a 3.70 rear gear
The datamaster I am using says that I am running 13.7 in the 1/4 mile. (I ran 13.7 before the cam cylinder heads and roller rockers were upgraded) Does this seem ridiculous?
I found out that we had a spun rod bearing so now we are making it into a 383. I was wanting to know what I might do to match my combo better maybe a 58mm throttle body instead of the stock one?
What kind of times should I get?
Old Mar 13, 2004 | 03:51 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd go w/ either a 52 or 58 mm tb. Don't know if you will pick up any power or not over a 52, but might as well go 58 is you are spending the money. I have a 58mm and it seems to work fine.
If everything is done right, I'd guess you should be in the high 11's, low 12's, depending on traction, tuning, and supporting mods.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
