Turn key, 2 second pause before cranking
Old Mar 13, 2004 | 10:07 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Yes its another starter question. I have searched but yet to find one that has the answer.
It started about a month ago.. the starter is less than a year old. When I turn the key their is about a 2 second pause before it starts to crank. Could it be the starter or be something with the wires?
Old Mar 13, 2004 | 11:25 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
maybe it's the VATS
Old Mar 14, 2004 | 01:13 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Vats jsut kills the fuel.
Old Mar 14, 2004 | 10:02 AM
white91Z28's Avatar
Engine: TPI 350
its not getting heat soaked either.. because it also happens when I first start it up in the morning.
Old Mar 14, 2004 | 10:08 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
do you have a starter kill/alarm/automatic starter?
Old Mar 14, 2004 | 11:22 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
The VATS in my 89 iroc controlled a relay in the wire that went to the starter solenoid, which disabled the starter. It's easy enough to jump, just remove the relay and put a 10 gauge jumper wire between the thick green and thick yellow wires.
Old Mar 14, 2004 | 12:42 PM
Car: 88 Camaro SC
Engine: SFI'd 350
huh... the tpi cars actually have that? On the C3's it jsut cuts the fuel. Learn something new every day.
Old Mar 14, 2004 | 04:46 PM
white91Z28's Avatar
Engine: TPI 350
no
Old Apr 4, 2004 | 01:51 PM
pat12spe's Avatar
Mine does this as well, but it started after I got an alarm system installed. There is a starter relay they put in there for some reason that doesn't let the car crank for a couple seconds. Don't ask me why, I guess it's just a security measure. Maybe it's part of your VATS system or something.
9192camaro
16
Feb 3, 2019 12:21 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
wayshegoes
Aug 17, 2015 12:00 PM
