Aussie Right Hand Drive Conversion
Old Mar 13, 2004 | 11:45 PM
Tils's Avatar
Car: 1984 Camaro, 1984 Vette
Engine: 307
Transmission: t700
Hi All,
I've had a 84 305, quadrajet camaro for a while and I'm currently in the process of cleaning up the entire engine bay, what I have found is that when the conversion was changed from left hand drive to right alot of the emmission hoses, wires are all over the place, I was hoping that someone with the same vehicle could send me a heap of photos of their engine bay (air filter off), or someone can point me in the direction of some good text specifically on the hose and wire setup
Thanks to anyone who can help
Cheers
Old Mar 14, 2004 | 03:46 PM
Vader's Avatar
Tils,
Welcome Aboard!
I might not have a lot on the wiring, but this may help with your hoses:
If your's is a US model:
If your's is an "export" model:
Old Mar 15, 2004 | 03:04 AM
Tils's Avatar
Engine: 307
Transmission: t700
have this sticker already on the, thankyou anyway
Old Mar 17, 2004 | 06:46 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
I've an '82 right hand drive converted Trans Am, done by Maracoonda Auto in Queensland. I pulled my emissions stuff off which made my car run better. Why do you want to connect yours back up?
Old Mar 19, 2004 | 11:04 PM
Tils's Avatar
Engine: 307
Transmission: t700
I don't - I'm ripping the air con and everything else that is not essential. At the moment there are hoses that go no-where, are blocked up with screws, I want to get back to what is should be so I can start removing
Old Mar 20, 2004 | 02:47 AM
Car: 1989 Trans Am
If you could post a picture of your engine bay, I could point out some things if you like. I also removed my air con and some other bits.
Infested
May 22, 2018 11:56 PM
evilstuie
Feb 28, 2016 03:33 PM
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
Bull86
Aug 10, 2015 05:43 PM
