will not drop to idle
Old Mar 14, 2004 | 10:00 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
When I clutch the car at a light or even changing gears it will not fall to an idle for several seconds. It drops to around 1400 or 1500 ,sometimes more, its several seconds before it will drop to where it should be.I have changed IAC.
Old Mar 14, 2004 | 03:27 PM
Damon's Avatar
Is the TPS reading correctly. If it's reading high the ECM will somtimes hold a high idle for a while before it realizes it's being lied to.
Old Mar 14, 2004 | 06:44 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
I have had 3 TPS go bad in the last year. I'll check it out and see what reading I get
777Shock777
Oct 29, 2015 04:30 PM
IROCtometal
Sep 20, 2015 11:08 PM
db057
Sep 4, 2015 07:57 AM
IROCtometal
Sep 2, 2015 02:01 PM
