Harmonic Balancer problems
Old Feb 20, 2001 | 10:40 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I noticed that it moved back enough to saw through a coolant line behind it. I cut the section of metal pipe that the balancer was hitting. and went around it with a rubber hose. Is it safe to drive if the harmonic balancer is bad??
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Feb 20, 2001 | 11:30 AM
ede's Avatar
ede
if your damper is bad don't drive your car.
ICON Motorsports
1st & 3rd
Old Feb 20, 2001 | 11:31 AM
R.O.B.'s Avatar
NO, its not safe! If it moves enough, it could wear a hole through the timing chain cover. Not to mention, the balancer is now not able to perform its job. Get a new one from the dealer, about $85, and install will take you about an hour. Also highly recommend to go to your local parts store and rent the puller/install kit.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 20, 2001 | 09:05 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Plus imagine the sheetmetal damage that sucker could cause if she comes off. Even at low rpms that thing has a lot of girth to it!
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
