Which cam...Cam "A" or cam "B"
Old Mar 16, 2004 | 01:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Heres the motor:
383 stroker (built ZZ4)
going with about 10:1 compression
3000+/- stall speed
3.73 rear gears
Assuming the heads support the cam, which of these 2 solid rollers is the best match. I want streetability, not afraid to use vacuum assist or a canister. Both are Xtreme Energy profiles.
the first cam is the XR280r:
280/286 adv. duration
242/248 @ .050"
.571/.577 with 1.5 ratio
110 LSA
The other is a custom grind (XE lobes)
280/292 adv. duration
242/254 @ .050"
.571/.583 with 1.5 ratio
113 LSA
I dont feel like changing the gears or the compression. i called comp and said depending on the engine size, the custom grind is about 2800-6800. Could be 3000-7000. With the above build, which cam would best suit my needs. Im planning on using nitrous. remember, i need streetability. I have MY ideas, but id like input.
Old Mar 16, 2004 | 01:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Between those 2, it's a no-brainer... the one with the larger exhaust lobe and the wider LSA. I don't see a major streetability difference between the 2; the 2nd will idle a little better, but the first will make a little more torque at a lower RPM.
Old Mar 16, 2004 | 01:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heh, i almost bought that first cam for my 400..
when you say streetability, what exactly do you mean? is it just "if i can run enough power brakes to stop" streetable, or what?
Old Mar 16, 2004 | 01:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Ok, that was my initial thoughts, too.
damn that was a fast response, RB.
by streetability, i mean, i dont want to have to stall to high heaven. It has to survive daily light-to-light at times, but be able to hold its own on the e-way. im not afraid to run a vacuum can for brakes, but i want enough vacuum to not be forced into an electric pump. Looks like the latter cam is my choice.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
